starting issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 12-09-2010, 11:20 PM Thread Starter
starting issue
I have a Vulcan 750 2006 which runs great and starts just fine when cold. Once the engine is hot I have great difficulty starting it. It is a little embarrassing at the gas staion when I can't leave.
Anyone with similar issues or ideas?
Thanks,
Curley
curley is offline
post #2 of 4 (permalink) Old 12-09-2010, 11:47 PM
Common issue, try changing to the NGK Irridium plugs and if you don't have a AGM battery, get one. That usually clears it up.
post #3 of 4 (permalink) Old 12-09-2010, 11:47 PM
Ceal's Avatar
I read about this on the forum... have you read through the Vulcan verses?
I dunno if I remember correctly, but I think this can be fixed by modifying the pickup coils' gap. Also, I think an AGM battery and Iridium plugs help reduce the problem.
Ceal is offline
post #4 of 4 (permalink) Old 12-09-2010, 11:50 PM
stiervulcan's Avatar
One question I have is, does this only happen at the gas station? I found the same problem if I filled it too much, make sure to leave space between the "neck"(is what I will call it) and the gasoline level.
K&N filters
MF-AGM Battery
93' VN750 / 13,600mi
Vestal, New York
stiervulcan is offline
