Spline seal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 11-23-2010, 01:51 PM Thread Starter
Spline seal
I guess I need to do the Spline lube. I'd like to avoid down time so I understand I should order at least one of the common seals. Is the seal that typically needs replacing P/N 92055A? I'm going to try to find the high Moly grease locally but if not is there a good place to buy online? We only have a Harley dealership in town and they've never heard of Moly. I was able to pick up some good synthetic gear lube at Walmart. Its similar to the stuff I use for my outdrive on my boat.
-Robert
RobertGary1 is offline
post #2 of 6 (permalink) Old 11-23-2010, 06:46 PM
wicker san antonio
Spline lube...seals?
There is one O ring behind the splines on the shaft that sticks out of the final drive unit. Part no 92055... When you order the O Ring from a Kawi dealer they should have the 'moly 60 paste'. I got my Orings and the moly from Alamo Cycle Plex in San Antonio. Their phone no is 210 696 2000. The O ring costs about $5 and the moly cost$ 10.98 for a small tube about 6 inches by 2" (fits small grease guns). Part No. 92055A is not the correct part. The moly I bought from Alamo is made by Honda.
BTW if you have not discovered Fergy's How To on lubing the splines , I highly recommend: http://pages.tstar.net/~fergy/writeu...al_drive1.html.
It has pictures and step by step procedures.
Good luck. The procedure is really easy and staight forward.
Wicker/ San Antonio
wwicker:
wwicker is offline
post #3 of 6 (permalink) Old 11-23-2010, 09:39 PM
The Honda moly 60 refers to 60% molybdenum in the lube.
Here`s a thread with at least a couple of links to moly 60 lube, and some discussion on the pros and cons of using other lubes.
https://www.vn750.com/forum/showthread.php?t=10181
post #4 of 6 (permalink) Old 11-24-2010, 10:24 AM
n2omike's Avatar
I got mine off ebay from these guys. Fast shipping, no problems.
One tube $10.94 w/free shipping.
http://cgi.ebay.com/ebaymotors/Genui...Q5fAccessories
Two tubes $21.19 w/free shipping.
http://cgi.ebay.com/ebaymotors/2-Tub...Q5fAccessories
n2omike is offline
post #5 of 6 (permalink) Old 11-24-2010, 11:23 AM
Seems like that one tube would do the job a few times, & free shipping would make it hard to beat... I paid out the yazoo for my 70% when I bought it, quite a bit more than that...
__________________
post #6 of 6 (permalink) Old 11-25-2010, 01:24 AM
'03 VN750 "Rosie"
bstew7890's Avatar
Hmmm. I'm starting to think the "Hi Temp Wheel Bearing Grease" I put on there 2000 miles ago may not be sufficient. But isn't there even more friction going inside a car's wheel hub than in the driveshaft splines?
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
