Helmet locks - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 11-17-2010, 10:18 PM Thread Starter
Helmet locks
Any suggestions for helmet locks and placement? It seems there are a few out there.
-Robert
RobertGary1 is offline
post #2 of 15 (permalink) Old 11-17-2010, 10:43 PM
Concert connoisseur
wib714's Avatar
if you dont have them on your vulcan, find a set of used ones and rekey them to match your ignition so you have only one key. mine are on the grabrail stock but not sure I like them there!
link on rekeying them in my sig line!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 15 (permalink) Old 11-17-2010, 10:55 PM
I just did a search on *helmet lock relocation* and found a new one to me, relocated to the front wheel. Looks kind of cool.
https://www.vn750.com/forum/showthrea...ock+relocation
post #4 of 15 (permalink) Old 11-18-2010, 12:17 AM Thread Starter
The stock one does sound better. Any suggestion on where to locate a used stock one?
-Robert
post #5 of 15 (permalink) Old 11-18-2010, 05:55 AM
Concert connoisseur
wib714's Avatar
ebay! or post here in the for sell section. someone will have a couple spares dirt cheap!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #6 of 15 (permalink) Old 11-18-2010, 06:08 AM
I just use a padlock and lock the helmet to the rear rack or mirror stem.
Yeah, with it on the mirror stem, someone could unscrew it, but the lock would still be attached.
Usually, anything that makes something harder or longer to take makes a potential thief move on.
post #7 of 15 (permalink) Old 11-18-2010, 07:02 AM
You can get them that bolt on your frame or handlebars... You can cut a "T" shaped piece of aluminum and make it a double holder...Then there's the free gun lock stuff that is still cheaper... Also even if you don't want to carry another key, you can always keep it somewhere on the bike till you lock up your helmet...
Don't forget, if you have one of the cable locks for your bike, that can be used also, if one end is small enough to go thru the D ring...
I don't think I would go for the wheel mounted one, as I don't like it there, and also think you would have to take your wheel and get a rebalance...
Just ramblin...lol.........
post #8 of 15 (permalink) Old 11-18-2010, 08:52 AM
-Robert
I'm pretty sure I have an extra one at home. If I do, I'll send it to you if you want. You'll have to rectify the key situation though. I don't have a spare one of those.
LibertyPilot is offline
post #9 of 15 (permalink) Old 11-18-2010, 11:24 AM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Do you have a sissy bar on your bike? I'm eventually going to move mine so when I plop my helmet on top of the sissy bar, the lock will be where the D-rings hang. This would make it appear at a glance that the helmet is just sitting on the sissy bar but is really also locked up.
Chris and Shim is offline
post #10 of 15 (permalink) Old 11-18-2010, 11:47 AM
baldy's Avatar
I have 4 of them that I took off my bikes. I don't wear a helmet so no use for them. Shoot either LP or I a PM and we'll set you up.
Same thing with the key situation too.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
