"Vulcan 750" side badge - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 11-04-2010, 01:18 PM Thread Starter
My "Vulcan 750" side badge (in front of the battery) is broken. Where would I locate a replacement?
Thanks!
94 750
-Robert
RobertGary1 is offline
post #2 of 10 (permalink) Old 11-04-2010, 01:31 PM
Thanks!
94 750
-Robert
Just break the other side too - problem solved.
accord_guy is offline
post #3 of 10 (permalink) Old 11-04-2010, 04:02 PM
flitecontrol's Avatar
These folks may have them. They won't be cheap anywhere, though. http://www.cheapcycleparts.com/
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 10 (permalink) Old 11-04-2010, 05:18 PM Thread Starter
Excellent website. Diagrams and everything. Thanks!
-Robert
post #5 of 10 (permalink) Old 11-04-2010, 07:20 PM
Scootergptx's Avatar
I took them off the chrome covers I bought. My guess is I tossed them in the trash. I didn't see them last weekend when I was digging through the parts crate.
Global warming? So what if my kids never see a polar bear. I never saw a dinosaur and I'm ok.
Scootergptx is offline
post #6 of 10 (permalink) Old 11-05-2010, 01:20 PM
Joem's Avatar
Peel the rest off. Looks better without them. They are usually faded anyway.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #7 of 10 (permalink) Old 11-06-2010, 12:55 PM
peerless's Avatar
Thanks!
94 750
-Robert
I'm pretty sure that I have the one you need, if you still need it, you can have it (I removed mine). I'll dig around today and make sure. PM me if interested. I'll check back later and post for sure with the condition of it/them.
2004 VN750 "Rosanna"
Acquired March 6, 2010
Done:
NGK Iridium Plugs
NGK Caps
Big Crank ETX15L AGM Battery
Battery Tender Jr. w/Pigtail
Rear Spline Lubed
Front Spine/U-Joint Lubed
Metzeler ME 880's
Brake Fluid Flushed, Filled, and Bled
Saddlemen Studded Saddlebags and Tank Bib
Installed 12 Volt Power Outlet
Debaffled
R/R Relocated flightcontrol Style
Pending
N/A... I'm Going Ridin'
peerless is offline
post #8 of 10 (permalink) Old 11-06-2010, 01:36 PM
A piece of heavy fishing line slipped underneath and worked back and forth will get them off and leave little residue to clean ,if you go this route.rubbing alcohol will clean the rest,you have to do this even if you replace it.
post #9 of 10 (permalink) Old 11-06-2010, 01:42 PM
peerless's Avatar
Same method here except I used goo gone to clean it up. I heated it a little with a blow dryer before starting.
Done:
NGK Iridium Plugs
NGK Caps
Rear Spline Lubed
Metzeler ME 880's
Debaffled
Pending
peerless is offline
post #10 of 10 (permalink) Old 11-06-2010, 03:58 PM
Straight roads are evil
Part numbers:
56014-1272 EMBLEM,FUEL TANK,LH $19.88
56014-1273 EMBLEM,FUEL TANK,RH $19.88
56050-1772 MARK,SIDE COVER,LH $18.09
56050-1773 MARK,SIDE COVER,RH $19.04
Prices are from cheapcycleparts.com. Will be slightly higher from a Kawi dealer. No idea why the right side cover costs more than the left.
http://www.cheapcycleparts.com/model...semblies/73231
2006 VN750 (SOLD)
63160 miles
Mustang seat
Red spark plug wires
Stainless Steel brake lines
Stiffer fork springs
Givi bags, Wingrack mount
GPS Mount
Pashnit sticker!
EQPlayer is offline
