1985 VN700 will turn over but will not idle (im a newbie please help) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 09-16-2010, 09:19 PM Thread Starter
I have just bought a 1985 VN700. It didnt have any gas when I looked at it, so it turned over but it obviously didnt stay running. I brought it home and put gas in it and sure enough even with gas it will turn over and run for a split second, but with any gas given or even choked it will die. I assume it might be a carb problem. Please if you have any information on this issue or if you could just point me in the right direction that would be great. I want to learn my self I dont want to have to take it to a mechanic. Thanks for your help.
matthewdavidwatson is offline
post #2 of 18 (permalink) Old 09-16-2010, 10:05 PM
Welcome to the Vulcan madness Matthew.
If the bike has been sitting for a long time and the fuel evaporated out of it in your Texas heat, the tank and carbs could be gummed up with varnish. Try pouring 6-8 ounces of Seafoam fuel conditioner or even some fuel injector cleaner into the tank of fresh fuel. Find the carb float bowl drain screws and drain the fuel out of them. Turn the petcock (fuel valve on the bottom left side of tank) to the Prime (PRI) position found only on the earliest 3 or 4 model years. This will allow fuel with the Seafoam to flow and fill the carbs too. Let it sit for a day or two, and try to start it once in a while.
If it still won`t run, check for fuel flow from the tank, and vacuum hose to middle nipple on petcock is not broken or cracked.
Here`s a link to the Vulcan Verses with info on flushing out the carbs through the drains.
https://www.vn750.com/forum/showthread.php?t=1080
You might find this link interesting too.
http://www.dansmc.com/MC_repaircourse.htm
post #3 of 18 (permalink) Old 09-16-2010, 10:13 PM
flitecontrol's Avatar
Welcome, Matthew. As OlHoss said, carb problems are common on bikes that sat. When you change the oil, do it with the bike on the sidestand. After removing the drain plug, stick a finger in the hole and pull out the spring, flat washer and screen. Look for any foreign material on the screen, especially chunks of rubber. Bikes of your's age tend to have deteriorated balance dampers. The rubber damper parts usually show up on the screen before major damage occurs (see my project bike info in signature). Also, check the tank for rust since you're in a pretty humid environment. It forms because of condensation in the bottom of the tank first. Try to get a look with a small flashlight and mechanic's mirror.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 18 (permalink) Old 09-16-2010, 10:34 PM Thread Starter
Thank you Olhoss and flightcontrol!!! I will do both, drain gas from carb then put in fuel injector cleaner let sit for a day or so and see if runs. Also, I will change the oil and check spring, flat washer and screen. One question though, does the spring, flat washer and screen just pull right out with a, for lack of better word, tug?
post #5 of 18 (permalink) Old 09-16-2010, 10:35 PM Thread Starter
OH one more question. The gas tank is rusted inside! Whats the best way to correct that issue?
post #6 of 18 (permalink) Old 09-16-2010, 11:26 PM Thread Starter
Also one more thing. There is a gooey substance that is now on my garage floor that feels like oil but smells like gas...It had to of happened when I was trying to start it going back and forth from the PRI to RES on my petcock. Any idea where that could be coming from and why?
post #7 of 18 (permalink) Old 09-16-2010, 11:46 PM
MANIC MECHANIC
vulcanjoe's Avatar
sounds like a stuck float as far as the rust muratic acid and naval jelly use the search to find it
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #8 of 18 (permalink) Old 09-17-2010, 09:24 AM
I used The Works toilet bowl cleaner, avaiable at WalMart for around $1.25 per 16 ounce bottle. It runs around 20% hydrochloric acid and the muriatic is 40% hydrochloric. Fergy, a member of this forum, has a good write up on using muriatic acid. Locally, I could only find muriatic in a gallon container, and you won't need that much. I think I only used one bottle of The Works to do two tanks. When finished, I poured what was in the tank through a coffee filter and put it back in the bottle.
You can do a search for my write up here, or Google: The Works Tank Cleaner. One guy used acetone to dry the tank. I don't recommend this as one spilled drop instantly ate my tank paint. After rinsing the tank with water, immediately give it a really good shot of WD 40. It will displace the water and prevent flash rusting.
"Black Beauty"
Old Blue
post #9 of 18 (permalink) Old 09-17-2010, 02:34 PM
The gooey crap on the floor sounds like rotten old gas on the way to becoming varnish or gum.
post #10 of 18 (permalink) Old 09-17-2010, 02:44 PM
clock152's Avatar
Matt...I had all of these issues when I got my bike.. it had sat for probably 5 or 6 years.. ran seafoam (great stuff btw.. cant live without it) thru many times.. jsut seemed to get worse... finaly had a float stick on me so I ended up pulling the carbs (not that hard really).. took the carbs apart to clean em (I'm pretty sure they had never been off of the bike since it was new in 1992!.. had enough stuff in the carbs to build a 2nd bike with!..while the carbs are out I am doing an ear shave.. might as well right!.. my point is.. you will probably just have to bite it and go all the way with this old girl.. it will be worth it!
clock152 is offline
