Rust removal IT WORKS! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 09-10-2010, 08:15 PM Thread Starter
dirtrack650's Avatar
Thumbs up Rust removal IT WORKS!
I picked this up from Harbor Freight and gave it a try - IT WORKS. I tested it on an old hammer head that was completely rusted and in about 3 hours it's bare shinny metal. Next test is my Honda CT70 gas tank that needs a rust clean out.
I'll follow up with the results...
EVAPO-RUST
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #2 of 12 (permalink) Old 09-10-2010, 08:22 PM
Ceal's Avatar
funny name... reminds me of va-poo-rize lol
Ceal is offline
post #3 of 12 (permalink) Old 09-10-2010, 10:17 PM
1985 VN-700
L2fish's Avatar
Im gettin me some. Is it like naval jelly?
L2fish is offline
post #4 of 12 (permalink) Old 09-10-2010, 10:42 PM
flitecontrol's Avatar
Don't think so. Most Naval Jelly contains an acid. This stuff has no acid according to the msds.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 12 (permalink) Old 09-10-2010, 11:48 PM Thread Starter
It's a clear liquid the consistency of 30 weight oil.
I also tried CLR. This worked very good removing rust from the gas cap of the CT70.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #6 of 12 (permalink) Old 09-11-2010, 09:06 AM
Not to hijack the thread, but was wondering what would work that good on corroded aluminum...??? That stuff really got some great reviews as a rust remover...
I see some corrosion on the aluminum engine parts on my car and was wondering what might be good for that...
post #7 of 12 (permalink) Old 10-04-2010, 09:53 PM
I used Metal Rescue on the back of my chrome exhaust heat shields. It cleaned the rust from around the clamps before they could weaken and break off. Its consistency is almost as thin as water.
Here Metal Rescue is used to clean a fuel tank.
http://www.youtube.com/watch?v=Hb7jyf7A4WE
post #8 of 12 (permalink) Old 10-04-2010, 10:00 PM
Google "aluminum cleaner" OD.
There is a whole schwack (technical term) of links there for cleaners.
post #9 of 12 (permalink) Old 10-05-2010, 06:12 AM
wolflrv's Avatar
I will vouch for the Evapo-Rust! I'm using it to refurbish my gas tank and will probably soak a ton of rusty bolts and screws with it too, before repainting them. It's working very well so far even on heavily crusted parts!
New rider/mechanic of '85 VN700 Vulcan. (25k miles)
Link to bike restoration blog:
http://trailofthewolf.blogspot.com/s...%20Restoration
wolflrv is offline
post #10 of 12 (permalink) Old 10-05-2010, 03:34 PM
I used purple power de-ruster from advanced auto part and it worked perfect as well, the only issue is since I used a hvlp to apply it all the atomized sulpheric acid took me out even though I had a mask on. so use in a well ventalated area. The bottle says it coats the metal as a pre paint conditioner and once it has fully cured you can spray right on top of it.
Harley sportster fenders
custom raked front end
custom exhaust
vn800 tank and guages
modified seat and recovered
rear frame chopped
custom wiring harness
airbox removed
hzhardy is offline
Tags
rust gas tank
