Need some input on body work.. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 09-09-2010, 03:10 PM Thread Starter
artemis_f0wl's Avatar
Send a message via AIM to artemis_f0wl Send a message via Yahoo to artemis_f0wl Send a message via Skype™ to artemis_f0wl
Hello again!
I recently removed my tail/brake light and turn signals, electing to replace them with a license plate frame which has all the lights built in. It really slims down the back of the bike and I really like the looks! However, I am now faced with 3 holes in the back of the fender where the old brake/tail light bolted on. Can anyone help me understand how to fill these so they can be primed and I can repaint? I've never done this before so any input, tips, or suggestions are welcome.
NIL ILLEGITIMUS CARBORUNDUM
Phil aka Art
"Vanessa"
1995 VN 750 (bought as 2nd owner 11/2008)
26,440 miles
Stator replaced (55 Days!)
V&H Cruisers
Relocate rear turn signals
Highwayman Saddlemen bags
Wingerline Highway bars
Ear Shave
Rejet carbs
R/R relocate
Kuryakin ISO Duallys all around
HD Heritage seat
12" ape hangers
To Do:
Some sort of new grips
Mirrors
Paint Job- should I do it myself?
artemis_f0wl is offline
post #2 of 18 (permalink) Old 09-09-2010, 11:29 PM
Clean the paint off down to the metal, for an inch or so around the holes on both sides, top and bottom of the fender. Get a body shop to fill in the holes with a MIG or TIG welder. Smooth it out and prep for repainting.
I have never done it, just my DIY side thinking out loud.
Maybe more experienced bodymen will offer other methods.
post #3 of 18 (permalink) Old 09-10-2010, 10:54 PM
Repairing holes
You can do it yourself with any mig or fluxcore welder just clean off around the holes and set the welder on low and slowly build up weld around the edge of the holes... grind it smooth prime and you should not ever know the hole were there... it is easier then it sounds....Btw Thanks to those who suggested the fix trick on the auto adjusters.. it cleared up the knock i would of swore was a rod ready to make an appearance out the side of my engine...
thanks again....
Dave F is offline
post #4 of 18 (permalink) Old 09-10-2010, 11:17 PM
MANIC MECHANIC
vulcanjoe's Avatar
I would recommend mig or tig not flux core. the flux core leaves a lot of spatter around the weld.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #5 of 18 (permalink) Old 09-10-2010, 11:45 PM
another idea if you aren't handy with a welder.. or one isn't accessible.. use fiberglass... glass the underside of the fender as well as the out side. Then use Filler (Bondo) to fill in the low spot if necessary. although I would go the welding rout myself.
post #6 of 18 (permalink) Old 09-10-2010, 11:48 PM
MANIC MECHANIC
vulcanjoe's Avatar
I would be afraid the fiberglass would crack
34k so far
coastered
spline lube
TPE stator
post #7 of 18 (permalink) Old 09-11-2010, 06:34 AM
the fiberglass wont crack because you are making a sandwich with the glass an metal, and because the glass would be less than an 1/8 of an inch thick in most places.. we are only talking of making a patch about 1/4 inc in diameter, not a whole fender.. even then you can get a whole fiberglass fender for a motorcycle that doesn't crack. I have been using a fiberglass seat pan on my bike for 2 years now without any signs of stressing or cracking. If you know how to use "Glass" properly, you won't have an issue.
post #8 of 18 (permalink) Old 09-11-2010, 07:48 AM
MANIC MECHANIC
vulcanjoe's Avatar
makes sense I just prefer to burn metal i guess
34k so far
coastered
spline lube
TPE stator
post #9 of 18 (permalink) Old 09-11-2010, 10:42 AM
I do too.. but not every one has access to a welder.. me included
post #10 of 18 (permalink) Old 09-11-2010, 11:14 AM Thread Starter
Ok, great input, thanks to everyone. But now to let me noob-ishness show through..
I borrowed a welder from a friend to fabricate my luggage rack/seat mount, I think it's a MIG welder- there is a metal alligator clip that connects to the metal and the wire fed from the gun. So I can use this to fill these holes in after clearing the paint down to the metal near the holes? I might strip the whole thing & paint another color. I've only tried to smooth one of the few welds I've made and that didn't go well. The weld was much harder than I'd expected. What is the ideal method for sanding this area smooth enough for primer?
Phil aka Art
"Vanessa"
26,440 miles
V&H Cruisers
Ear Shave
Rejet carbs
R/R relocate
HD Heritage seat
12" ape hangers
To Do:
Mirrors
