Speedo trouble, need help. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-23-2010, 10:48 AM Thread Starter
VN750_DawgsFan's Avatar
Wasn't sure where to put this so I figure this as good as place as any.
Anyway, as I turned onto the road my work is on this morning, my speedo quit working. I've checked the cable and it seems fine. The back light on the speedo lights up, but the needle doesn't move, neither does the odo or trip.
Not sure what's going on or where to begin to troubleshoot.
Any ideas?
VN750_DawgsFan is offline
post #2 of 4 (permalink) Old 08-23-2010, 10:56 AM
93VN750's Avatar
Could be the gear down on the wheel hub. Try spinning the cable connected to the speedo with a drill from the wheel hub end and see what happens. If nothing, either cable and/or speedo are bad. Cables go with a frequency, have not heard too many speedos going bad. If it works, replace the wheel hub sender.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 4 (permalink) Old 08-23-2010, 12:08 PM
baldy's Avatar
Set the bike on the center stand and lift the front wheel off the ground. Remove the cable from the speedo and have a buddy spin the tire fast and see if the cable turns. If it doesn't turn remove it from the lower connection and see if it is broken in the shaft by pulling it out. If it is not broken it could be the part at the wheel. Remove the wheel and see if the gear is frozen or came out of the tabs on the rim. If that is good it is in the speedo itself.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #4 of 4 (permalink) Old 08-23-2010, 12:23 PM
Jon
You know, seems like I had a very simuliar thing happen once when I had a front wheel off, didn't get something meshed up right on the speedo and had to re-do it...
CRS limits my help...lol...
