Help! Lost nut/insulator to my engine mount !! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 08-22-2010, 11:16 AM Thread Starter
Rogue Warrior
Rogue's Avatar
I lost the nut/insulator to my engine mount !!
Fortunately I didn't lose the looong bolt that goes through. Didn't notice it until I pulled up to my garage and saw the long bolt nearly out, just behind my leg!
Can anyone out there help me out?? I need the nut/insulator for the top rear engine mount bolt. It looks like they are all the same though?
What say ye brethren of the bike?? Anyone have one leftover from a rebuild or spare/parts bike??
'86 Vulcan 750
Sold Dec. 2010... after many enjoyable rides.
27K miles and going strong thanks to vn750.com !
Windshield, Deluxe Soft Grips, Vista Cruise Control, Leather Saddle Bags,
High Back Rest, Luggage Rack, Highway Brackets & Pegs, NGK plugs and wires.
Ignition Issue - Fixed! Replaced Hockey puck.
ACCTs- Grambo Trick worked!! TOC ACCT Springs installed!
Rogue is offline
post #2 of 10 (permalink) Old 08-22-2010, 09:44 PM
Concert connoisseur
wib714's Avatar
if you cant find one just take the bolt to the hardware store and match a metric up, plus a lockwasher. thats what I had to do, I rode 12 miles holding mine with my hand on the left side of the bike (by the threads) it was pretty warm too. I'm guessing yours was the top rear too!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 10 (permalink) Old 08-22-2010, 10:02 PM
baldy's Avatar
I think the road gremlins have found a new thing. Loosen the top rear engine mount bolt on our 750's! This is the 4th or 5th time I have heard someone with this problem in the last month. hmmmmmm? lol
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
post #4 of 10 (permalink) Old 08-23-2010, 08:46 AM
OldBikeNewRider's Avatar
I lost the nut but was riding with a buddy at the time and he noticed the bolt starting to fall out. I just went to the hardware store and bolt a new one. Looks like this might be a common thing. Went over the bike and tightened everything. Seems like this is a pretty good practice to get used too.
1986 VN 750
20,000 miles
Replaced Stock Turn signals
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
OldBikeNewRider is offline
post #5 of 10 (permalink) Old 08-23-2010, 08:56 AM
Send a message via Yahoo to luigit
loctite wouldnt hurt either. get the BLUE not the RED (the red is semi-permanent and is a bitch to remove).
PM sent on the bolts.
luigit is offline
post #6 of 10 (permalink) Old 08-23-2010, 10:05 AM
I agree 110%...Ole Blue, will get you through...lol...
post #7 of 10 (permalink) Old 08-23-2010, 10:52 AM
wvshaneb's Avatar
This just happened to me a couple months ago. I ordered the nut, bolt and insulator from cheapcycleparts.com. I had to order the bolt too, since my only "hardware store" option at the time it fell off was Lowe's. They had the correct diameter but wrong thread pitch, so I forced it on the old bolt to get me home and rode it that way until the new parts came in. I lost the damper between the nut and frame(part #92075-1738) as well as the ceramic insulator between the frame and the engine(part #16073-1058). I didn't realize the one on the inside was missing until I pulled the old bolt out for replacement and the one on the right side fell out. So make sure you get all your parts so you don't have to tear it apart twice.
Mom, I'm not wearing my helmet only for the purpose of taking this picture and
the background was digitally blurred to make it look like I'm going really fast.
wvshaneb is offline
post #8 of 10 (permalink) Old 08-23-2010, 03:24 PM
I think I have a spare one your welcome to. Hit me up with a PM if luigit doesn't have what you need.
post #9 of 10 (permalink) Old 08-23-2010, 07:17 PM Thread Starter
Rogue Warrior
Rogue's Avatar
Missing nut!
I had tightened it a couple times before.
Next time it will get a coat of Blue!
'86 Vulcan 750
Rogue is offline
post #10 of 10 (permalink) Old 08-23-2010, 07:47 PM Thread Starter
Rogue Warrior
Rogue's Avatar
Luigit has me covered! Thanks anyhow.
'86 Vulcan 750
Rogue is offline
