Question about 04 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 08-15-2010, 11:41 PM Thread Starter
peerless's Avatar
Question about 04
My brother has the offer to buy an 04 with 28,000 miles for $1,500. The good: Hard bags, good tires, new R/R, windshield, and according to the owner, it runs great. The bad: the owner says he sheared the coupler on the interstate due to a final drive failure. Obviously, it can't be ridden as is. If all the work is done by us, meaning me, are the parts available used at a reasonable price to make it a decent deal? I'm kind of straddling the fence on this one.
2004 VN750 "Rosanna"
Acquired March 6, 2010
Done:
NGK Iridium Plugs
NGK Caps
Big Crank ETX15L AGM Battery
Battery Tender Jr. w/Pigtail
Rear Spline Lubed
Front Spine/U-Joint Lubed
Metzeler ME 880's
Brake Fluid Flushed, Filled, and Bled
Saddlemen Studded Saddlebags and Tank Bib
Installed 12 Volt Power Outlet
Debaffled
R/R Relocated flightcontrol Style
Pending
N/A... I'm Going Ridin'
peerless is offline
post #2 of 9 (permalink) Old 08-15-2010, 11:52 PM
If you hear ir run and the mileage is right I'd jump on it if it looks good.I bought mine 92 partially disassembled for 650 and didn't get the hard bags and all the goodies,and spent some time and money to get it up and running .For 2 grand or under after repairs he should be set up.
post #3 of 9 (permalink) Old 08-16-2010, 08:29 PM
Calif Rider
weh44att's Avatar
That is a very good price for the 04 bike. Parts to fix it would not be that high in price to fix it. Check Ebay for VN 750 parts, any older parts will fit the newer bike. You should also check the charging system if you can to make sure the Stator is in fine shape. I am sure you have read that the bike may sound good but a bad stator will not keep it from running.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #4 of 9 (permalink) Old 08-17-2010, 10:03 AM
fergy's Avatar
It's a good buy. Start watching for final drives and couplers in parts bikes here and on ebay. My 02 (now my son's bike) has an 86 final drive on it and going strong...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #5 of 9 (permalink) Old 08-17-2010, 10:44 AM
Until you can actually ride it, you really don't know what you're getting.
I mean shearing a drive shaft sounds pretty radical to me.
What else is possibly 'sheared'?
Does it run nice?
accord_guy is offline
post #6 of 9 (permalink) Old 08-17-2010, 10:53 AM
fergy's Avatar
IF in fact the splines on the final drive/coupling are sheared, it is pretty (unfortunately, and ultimately avoidable) common. Especially for owners who are not members of VN750.com. The ones who are members here and have not checked/lubed their splines, have no excuse. If that bike were local, I'd snap it up and fix it, and sell it to someone who needs a bike, for a good price. The parts are not so unavailable as it might seem. It's the aftermarket stuff that is so hard to come by. It takes patience, but a final drive/drive shaft combo can be found in time. Of course, you won't know how the bike rides until this is fixed, but you can tell if the bike runs, and on the center stand, you can go through the gears even with the final drive shot to see how it performs. You could also check the electrical system before plunking down the cash. I would recommend all the above. But knowing what I know about this bike, I would probably buy it sight unseen for that price and go to work on it...
Fergy
2002 VN1500 Classic
SEAFOAM JUNKIE!
fergy is offline
post #7 of 9 (permalink) Old 08-17-2010, 10:56 AM
blair_220's Avatar
I jsut had to replace the final drive and coupler and all that. I got everything for about $ 400 which I thought was a good deal but have been told I paid to much. Like others have said check out ebay, or go to findmyparts.com and post an add most salvage yards check that site and will hook you up. not hard to change out either. I went ahead and got all new driveshaft and final drive
blair_220 is offline
post #8 of 9 (permalink) Old 08-17-2010, 11:23 AM
flitecontrol's Avatar
This one looks snipeable: http://cgi.ebay.com/ebaymotors/Kawas...Q5fAccessories
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #9 of 9 (permalink) Old 08-17-2010, 05:41 PM Thread Starter
peerless's Avatar
Thanks for all your help. I guess I'll just wait to see if by brother buys it and if so, look for the parts and put it together.
Done:
NGK Iridium Plugs
NGK Caps
Rear Spline Lubed
Metzeler ME 880's
Debaffled
Pending
peerless is offline
