Yes, Kuryakyn Floorboards on my VN 750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-11-2010, 04:06 PM Thread Starter
achaundy's Avatar
The left side fit like a glove, all I had to do was rotate the shifter just a little so my foot would slide under with ease. The right side is a little more difficult, had to cut the botton two mounting holes on the floorboard, then I had to add a 1" piece on the break pedal, just cut the pad off and weld the 1" extension on and weld the pad back on. had to tip it about 1/4" towards the back for a more comfortable foot position on the brake. It's not welded yet, I should have it installed tomorrow.
ID:	3021   Click image for larger version
achaundy is offline
post #2 of 3 (permalink) Old 08-11-2010, 06:17 PM
MANIC MECHANIC
vulcanjoe's Avatar
looking good
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 3 (permalink) Old 08-11-2010, 06:23 PM
They look good. Could you post some pictures taken straight on, from down level with the shifter. One with it in the original position and a second with it moved up one spline where you have it now. There are 32 splines on the shaft, so a one spline move is just over 11*. How far in inches did you raise it?
I would like to see some tech pics of the mods needed on the right side too.
You should know that we are as interested in the how-to-do stuff as the finished product. <G>
