cold start issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 08-01-2010, 11:48 AM Thread Starter
Concert connoisseur
wib714's Avatar
cold start issue
put in my ngk iridiums yesterday and it seemed to be running great. fired good too, this morning she did not want to fire, took it a good while. backfired a good bit. battery was reading 13.48 with bike off. between 13.5 and13.7 at idle when I finally got it started, 14.2 at 2000 rpm's and14.7 at 4000 rpm's. went to autozone and gave her a good 4 oz of seafoam in case it was fuel related, we'll see what happens.
any suggestions, I need to start riding to work again. hate going out and wondering "is it gonna start today"!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 20 (permalink) Old 08-01-2010, 11:53 AM
Mine works best with part choke, throttle rolled back all the way. And when it tries to start roll forward on throttle little bit at a time.
post #3 of 20 (permalink) Old 08-01-2010, 03:12 PM Thread Starter
Concert connoisseur
wib714's Avatar
on a cold start before the iridiums I had to full choke it and give just a little gas. so you think a part choke would make a difference now. and when you say rolled back all the way is that full throttle or no gas at all?
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #4 of 20 (permalink) Old 08-01-2010, 03:23 PM
Rolled back is no throttle and accually take your hand and roll it back against the stop.
Have you tried starting with no choke? And then hit the throttle a little as it turns?
post #5 of 20 (permalink) Old 08-01-2010, 05:45 PM Thread Starter
Concert connoisseur
wib714's Avatar
I'll try that in the morning when its good and cold. started all this afternoon just fine, so we'll see. thanks
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #6 of 20 (permalink) Old 08-01-2010, 05:51 PM
clock152's Avatar
good and cold.. good and cold!.. you suck.. its 102 here in Oklahoma...LOL...80's in the dark....there is no good an cold here.
clock152 is offline
post #7 of 20 (permalink) Old 08-01-2010, 06:24 PM Thread Starter
Concert connoisseur
wib714's Avatar
Oh its not cold here by no means, but it is not 102 either, mid 90's. I mean when the bike is good and cold.
still I'd take 102 anyday over 30's and even 40's let alone when it gets 10 here!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #8 of 20 (permalink) Old 08-01-2010, 06:29 PM
clock152's Avatar
True.. I dont see those temps untill late Jan.
clock152 is offline
post #9 of 20 (permalink) Old 08-01-2010, 08:13 PM
Calif Rider
weh44att's Avatar
Just a thought are your air filters clean? Do you sometimes have trouble with hot starts? Have you done the coil pick up adjustments yet, this may help. Did not see it mentioned in your mods that you have done.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #10 of 20 (permalink) Old 08-01-2010, 08:25 PM Thread Starter
Concert connoisseur
wib714's Avatar
no, yes and no.
I definately gotta do my filters next! hot starts are usually not a prob since the stator, rr and battery replacement. and are the pick up coil adj a rough job
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
