Advice Needed for new member. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-05-2010, 10:32 PM Thread Starter
I have been looking at bikes for a while.
this is something i can afford.
if all goes well i am going to buy it tomorrow.
I wanted some of your opinions to see if I need to dodge this one.
But, I am anxious to get a bike.
http://kansascity.craigslist.org/mcy/1826261313.html
any help would be greatly be appreciated.
I know some of you guys have an eye for this stuff, If you can give me some tips to look for or some points to haggle him down a little.
tizen is offline
post #2 of 11 (permalink) Old 07-05-2010, 10:34 PM Thread Starter
One thing that concerns me is They dont know the mileage and there is a leak from the oil eye level glass.
tizen is offline
post #3 of 11 (permalink) Old 07-05-2010, 10:39 PM
That poor thing has had a hard life. Maybe 500$ for it?
post #4 of 11 (permalink) Old 07-05-2010, 10:57 PM
IronMan750's Avatar
Wow, that looks like rat bike to me! $1000 is only the begining my freind. You're going to have to dig a lot deeper than that to make that bike dependable, even if you're Captain Handy. I'd keep lookin.........
2003
*Battery connected at both ends!
*Real air in the tires
*New Registration sticker
*Seat wiped off
*Low AND Hi beam headlight!
*New #1157 tail light bulb
*Brake pedal still on the right
*Custom valve stem caps made from black plastic!
*Custom built ignition key from Kawasaki
Does anybody really care?
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car"
IronMan750 is offline
post #5 of 11 (permalink) Old 07-05-2010, 10:59 PM
I agree, 1000 is a bit much for it with that much wrong with it... although I would still go check it out, make sure the sight glass is leaking... it is probably the gasket behind the sight glass, and not the glass itself... also find out why the speedo doesn't work. While checking out the bike, make a mental list of every thing that needs to be fixed now, and then go onto ebay and look to see how much money you will need to drop into it.
post #6 of 11 (permalink) Old 07-05-2010, 11:02 PM
peerless's Avatar
I'm thinking about the same price range. Along with the mechanical and cosmetic problems, I wonder if the owner has all the necessary parts to finish it, ie front and rear signal lights.
2004 VN750 "Rosanna"
Acquired March 6, 2010
Done:
NGK Iridium Plugs
NGK Caps
Big Crank ETX15L AGM Battery
Battery Tender Jr. w/Pigtail
Rear Spline Lubed
Front Spine/U-Joint Lubed
Metzeler ME 880's
Brake Fluid Flushed, Filled, and Bled
Saddlemen Studded Saddlebags and Tank Bib
Installed 12 Volt Power Outlet
Debaffled
R/R Relocated flightcontrol Style
Pending
N/A... I'm Going Ridin'
peerless is offline
post #7 of 11 (permalink) Old 07-05-2010, 11:07 PM
cglennon's Avatar
Way too much baggage! This looks like a money pit. Keep looking.
Chris Glennon - Portland, OR
cglennon is offline
post #8 of 11 (permalink) Old 07-05-2010, 11:35 PM
OldBikeNewRider's Avatar
Don't buy this one you can get a much nicer one for a few more $$ and save dough in the long run
1986 VN 750
20,000 miles
Replaced Stock Turn signals
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
OldBikeNewRider is offline
post #9 of 11 (permalink) Old 07-06-2010, 07:16 AM
Columbus, Ohio
jimkonst's Avatar
You can get a great looking, low mileage, great running bike for less that $2000. I did.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #10 of 11 (permalink) Old 07-06-2010, 09:17 AM
clock152's Avatar
That is way way to much for a "fixer upper".. I paid $175 for one parts bike and another $20 for another.. I got lucky!... but its been a long road to rebuild (2 years).. with that bike your going to drop more $$ than its worth.... keep looking.
clock152 is offline
