How many miles on reserve? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 04-20-2006, 08:51 PM Thread Starter
My odometer just hit 200 miles today on my 06, Fuel guage was on empty, Less than 2 miles from home the bike started sputtering so I switched to reserve, no problems. Half hour later I started the 3 mile trip to the gas station, didn't even make it a mile. How far should I get on reserve? Does mileage improve after break in?
Davejb is offline
post #2 of 12 (permalink) Old 04-20-2006, 08:59 PM
HAWK
Ccspinner's Avatar
Do you have a windsheld? I have noticed a little drop in MPG with my new Plexfairing 3, Still about 45 or so, and I have got 20 miles on reserve before I got to a gas station. I didn't want to push it past that
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 12 (permalink) Old 04-21-2006, 12:09 AM
Hello Dave, The most I have done on reserve has benn 15 miles. I normally go on reserve from 150 to 165 miles. The most I have ever got on a tank of gas including reserve is 173 miles and it took 3.41 gallon to fill it to the brim. Most of my riding is 55 to 65 mph. I have a Memphis shades fats shield on the bike, I do very little interstate riding, my weight is 220 lbs. I have 9500 miles on the bike.
Eriefisherman is offline
post #4 of 12 (permalink) Old 04-21-2006, 12:51 PM
Ihave a 2002 and drive between 70 & 80 mph on the interstate. I seem to get about 120 miles before having to go to my reserve.
However, when I keep it between 55 & 65, I get an additional 30+ miles before having to go to reserve.
I have driven about 20 miles on my reserve - afraid to take it much past that...
(I am 5'9 & 170 lbs for what that matters....).
Dom
dgcam55 is offline
post #5 of 12 (permalink) Old 04-21-2006, 05:04 PM Thread Starter
Ok, so any thoughts on why I didn't make it even 2 miles on reserve?
Davejb is offline
post #6 of 12 (permalink) Old 04-22-2006, 06:32 AM
You've got something wrong there. A new bike that won't go over 2 miles on reserve? It sounds to me like you never got to reserve. The bike can run a couple of miles on the gas remaining in the fuel lines when you shut the gas off. Are you sure you turned the fuel valve to the correct position? The lever needs to be pointing forward for reserve.
If you turned the valve to the correct position, you'd better take a look at the fuel lines and tank assembly. Maybe something is out of whack there.
CD in Frederick, OK
Ol Poop is offline
post #7 of 12 (permalink) Old 04-22-2006, 07:19 PM Thread Starter
Was definetly on reserve, even checked after it died. Can I run the bike normally on reserve just to make sure the valve is working properly?
Davejb is offline
post #8 of 12 (permalink) Old 04-22-2006, 07:45 PM
hi, when you ride the bike do you have the lever facing down or facing the front of the bike? john
free wheel-e is offline
post #9 of 12 (permalink) Old 04-23-2006, 11:16 AM
Now what
Ironman's Avatar
Sure. Fill it up, leave it on reserve and see how it runs. If it won't run on reserve, could be the pickup tube is plugged. That would definitely be covered on warranty. The other thing I'd try is get it going on RUN, then switch over to RES and see what happens. Shouldn't skip a beat.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #10 of 12 (permalink) Old 04-23-2006, 02:31 PM Thread Starter
Thanks, I'll give that a shot and see what happens.
Davejb is offline
