lifter tap cold - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-19-2010, 11:14 PM Thread Starter
SSLU50's Avatar
lifter tap cold
Will sea foam help with a lifter tap when cold? After oil gets warm, no problem.
SSLU50 is offline
post #2 of 3 (permalink) Old 06-20-2010, 01:12 AM
dirtrack650's Avatar
I bet it's your ACCT and cam chain guide.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 3 (permalink) Old 06-24-2010, 11:34 AM
baldy's Avatar
These engines have a little tapping when first started nothing to worry about.
If it was the ACCT it would do it worse when warm due to the chain stretching with the heat.
What do you run for oil? I use Castrol 20-50w and have very little tapping at start up. The thicker oil stays in the engine longer then thinner oils.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
