So the wire to the back out my Spedomter fell out while riding today - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-15-2010, 08:46 PM Thread Starter
CBH
CBH's Avatar
Yep, my spedometer stopped working and I was like come on!. Stopped at the next light and i was looking at the thing and a guy pulled up beside me and said "you got a wire hanging" I look down and there is the connector. I pulled over and tried to get it in, but it seemed short. I could not twist on the connector.
Any tips? Best way to run it back up to the spedometer so there is slack?
Thanks
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new throttle pull back cable
new spark plugs
New Bridgestone on the back
New Fluids all around
SeaFoam in the tank
CBH is offline
post #2 of 10 (permalink) Old 06-15-2010, 09:30 PM
1985 VN-700
L2fish's Avatar
That has happened to me a few times. You have to get the nut started just right and straight.
L2fish is offline
post #3 of 10 (permalink) Old 06-15-2010, 11:24 PM Thread Starter
CBH
CBH's Avatar
ok, thanks..I'll give her a shot tomorrow...
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new spark plugs
SeaFoam in the tank
CBH is offline
post #4 of 10 (permalink) Old 06-15-2010, 11:44 PM
MANIC MECHANIC
vulcanjoe's Avatar
it happened to me once i used teflon tape to tighten it havent had a problem since
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #5 of 10 (permalink) Old 06-16-2010, 09:38 AM Thread Starter
CBH
CBH's Avatar
I have some of that, good call...thanks
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new spark plugs
SeaFoam in the tank
CBH is offline
post #6 of 10 (permalink) Old 06-16-2010, 09:48 AM
GIMPYRDR's Avatar
Happened to me when I first got my bike. Had to take the windshield lose to get to it. Hands are to big.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #7 of 10 (permalink) Old 06-16-2010, 10:15 AM
If its short, it is either the wrong cable or routed wrong, try re-routing and be sure to have room to turn from stop to stop without binding...
It shouldn't come off if tightened properly, but if it did come off repeatedly I might thing about a speck of blue loc-tite or something...
Thats just me, others may see different & maybe better...
post #8 of 10 (permalink) Old 06-16-2010, 10:18 AM
Jocyne's Avatar
Same thing happened to me, mine was long enough to fit right back in but by the time someone told me while I was riding it had already been dragging for a while.
Jocyne is offline
post #9 of 10 (permalink) Old 06-17-2010, 10:40 AM Thread Starter
CBH
CBH's Avatar
Ya, mine dragged for a bi too ...lol.
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new spark plugs
SeaFoam in the tank
CBH is offline
post #10 of 10 (permalink) Old 06-17-2010, 12:23 PM Thread Starter
CBH
CBH's Avatar
So I got the cable in, went in pretty nice, I was puting it around the forks for some reason, but then realized what I was trying to do and put it between the forks. Went in Beauty after that. I'll keep checking it until I get some lock tight.
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new spark plugs
SeaFoam in the tank
CBH is offline
