It's Time to Play...Name! That! Motorcycle Part! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 06-11-2010, 11:40 PM Thread Starter
IMBoring25's Avatar
While digging into the left side cover to get to the R/R terminals, I dropped a tool into the labyrinthine cavity between the frame, the battery box, the engine, the swing arm, and all the other craziness going on there. I got it, but my magnet-on-a-stick also pulled out the following:
Apparently ferrous, overall length .285 inches, base diameter .500. There's a groove between the base and the next big cylindrical section.
Any ideas? I'd really like to hear it's not a motorcycle part or not an important one...
Thanks in advance.
IMBoring25 is offline
post #2 of 22 (permalink) Old 06-12-2010, 12:58 AM
The Professor
lance328's Avatar
It's part of the oil pump pressure regulator valve, and this is not good for you!!!
This can cause severe and/or catastrophic engine failure if this were an actual part from your bike. Just messin' with ya' !! ROTFLMAO
You picked up a stray part from a Harley!!!
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 22 (permalink) Old 06-12-2010, 07:34 PM
Ba dum dum, ching...
Ron_G's Avatar
It's either the cover from the Frazen valve or the end of the Shnanark pin which is what holds your degronerator up.
Yes, it's my mid-life crisis.
Sweet Jane...
http://images5a.snapfish.com/232323232%7Ffp63386%3Enu%3D457%3A%3E6%3C3%3E258%3E  WSNRCG%3D3345343785349nu0mrj
Ron_G is offline
post #4 of 22 (permalink) Old 06-13-2010, 03:27 PM
flitecontrol's Avatar
Trailer axle cover cap.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 22 (permalink) Old 06-13-2010, 03:57 PM
The Professor
lance328's Avatar
It's solid steel and only 1/2" in diameter so it would have to ba a very small axle.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 22 (permalink) Old 06-13-2010, 04:01 PM
Yeah, that's what I meant, off a very small trailer.
"Black Beauty"
Old Blue
post #7 of 22 (permalink) Old 06-13-2010, 04:18 PM
Do you ever see any clear smoke...???
Anyway it is the stopper for the left side of the smoke grinder, usually they smoke a bit but that is all, you can't usually see the smoke as it is clear...
If you put it back, be sure and clean the black off or sooner or later the smoke will be black and embarassing to ride... As black as that one is on the inside flat I would suspect someone has been running kerosene and moth balls for a while...
Of course that is just my opinion, others may see signs of some other fuel being run...
post #8 of 22 (permalink) Old 06-13-2010, 09:50 PM
It is not a motorcycle part...at least not a vulcans. My guess it is part of a small flashlight or the cap off one of those retractable magnetic tellscopic things you use to fish out lost parts in you bike...(Ironic huh?)
Just about all the motor parts are aluminum, and it definitely is looks like a cap for some tubular thing. At first I thought it was an old fork tube cap...untill I read the size.
There are alot of things that can fall into the works of someones bike that are not bike parts. Hell. I had mice living in my bikes tail section.......
post #9 of 22 (permalink) Old 06-13-2010, 10:06 PM Thread Starter
IMBoring25's Avatar
Not that ironic, in retrospect.
post #10 of 22 (permalink) Old 06-13-2010, 10:12 PM
kay
carbon unit
kay's Avatar
My guess is,it's a a cap from a universal joint minus the needle bearings one would nomally find inside. I think it could have been dropped there by the person who was trying to find something besides a marble to "marble" their reed valve hoses.
kay is offline
