Seat Question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-07-2010, 11:18 AM Thread Starter
CBH
CBH's Avatar
Seat Question
This is going to sound dumb, so bare with me.
I went to investigate my R/R, but I could not figure out how to get the seat off. On my Honda there was a release by the tank, it was simple. Help a dumb ass out? Thanks....lol
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new throttle pull back cable
new spark plugs
New Bridgestone on the back
New Fluids all around
SeaFoam in the tank
CBH is offline
post #2 of 3 (permalink) Old 06-07-2010, 11:56 AM
fergy's Avatar
No problem! We all had to figure this one out the first time. Inside your toolbox on the back of the passenger back rest is a couple of bolts coming from the backrest part of the seat. Remove the nuts and you should be able to tilt the seat up from the rear and then slide it back out of the tongue and grove fitting near the gas tank. You may have to remove the 10mm bolt holding on your toolbox which is also located inside the toolbox, and remove the toolbox before you can tilt the seat, as I can't exactly remember...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 3 (permalink) Old 06-07-2010, 02:06 PM
Rogue Warrior
Rogue's Avatar
Originally Posted by fergy View Post
.... Remove the nuts and you should be able to tilt the seat up from the rear and then slide it back out of the tongue and grove fitting near the gas tank....
Yup, that's it.
'86 Vulcan 750
Sold Dec. 2010... after many enjoyable rides.
27K miles and going strong thanks to vn750.com !
Windshield, Deluxe Soft Grips, Vista Cruise Control, Leather Saddle Bags,
High Back Rest, Luggage Rack, Highway Brackets & Pegs, NGK plugs and wires.
Ignition Issue - Fixed! Replaced Hockey puck.
ACCTs- Grambo Trick worked!! TOC ACCT Springs installed!
Rogue is offline
