Whining when I lean - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 05-26-2010, 01:07 PM Thread Starter
At Least I Can Spell!
msh1156's Avatar
Whining when I lean
All... since saturday I've noticed a steady whining sound when I'm leaning into curves. The sound modulates higher/lower in pitch based on speed and disappears when straightening up. Noise is present leaning to either side and isn't noticable until riding for a while. It appears to be coming from beneath or behind me, but it's tough to tell.
Michael
2002 Nomad 1500
VROC #29972
msh1156 is offline
post #2 of 14 (permalink) Old 05-26-2010, 01:18 PM
skalding's Avatar
I'd check your front and back wheels to see if there's any extra play. If it only happens when leaning the bike over, it may be related to the wheels somehow.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #3 of 14 (permalink) Old 05-26-2010, 01:49 PM
Cruisin' through my 50's
newOldUser's Avatar
Tell your passenger to stop being such a sissy.
Sorry... if it wasn't me it would have been someone else.
newOldUser is offline
post #4 of 14 (permalink) Old 05-26-2010, 02:05 PM
Columbus, Ohio
jimkonst's Avatar
I don't know, but could it be a low oil situation, or oil not circulating? Like if something is uncovered that is usually wet with oil?
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #5 of 14 (permalink) Old 05-26-2010, 03:18 PM
Dammit, I was going to say "don't ride 2-up."
LibertyPilot is offline
post #6 of 14 (permalink) Old 05-26-2010, 04:57 PM
Rook's Avatar
I'm gonna go with tires check your press and look for any cupping
Rook
Conway, AR
VROC # 30581
WBRA #90237-1
2009 1700 Nomad (mine)
2003 VN750 "Prozac" (now hers)
25'000 miles at purchase
Ears shaved
Cobra exhaust
So, why is a raven like a writing desk?
Rook is offline
post #7 of 14 (permalink) Old 05-26-2010, 06:47 PM
Give the man a cigar. Likely culprit here is the tires.
Oddly , some tires only seem noisey in turns. I remember running some Dunlap K-81's on my RD400 that almost howled when leaned way over.
Also keep in mind when you are "leaned over" your ear is able to pick up noises that are reflected off the road alot easier.
My only real suggestion here is to check your tire pressure and then not worry about it.
post #8 of 14 (permalink) Old 05-26-2010, 11:25 PM
msh1156 you have owned the Vulcan for about 16 months. Is this still the first set of tires you are running? The thought occurs to me that if the tires are getting close to being worn out, the tread in the center will be the most worn, and better/deeper sipes on the chicken strips may howl or whine more when leaned over. JMHO
post #9 of 14 (permalink) Old 05-27-2010, 12:58 AM
HAWK
Ccspinner's Avatar
Mine did that when they were ready for replacing, Tire is the problem.
Get a set of Metzlers and you wont be sorry.
Also look into upgrading to 110 front instead of the 100 it has stock.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #10 of 14 (permalink) Old 05-27-2010, 01:35 AM
Sounds like tires are the problem (or at least the cause of the noise) if they are still good treadwise and not badly cracked, I'd go ahead and wear them out before replacing them. The whine wouldn't bother me at all, as long as I knew what it was.
A few other remote possibilities. Check the final drive oil, if you haven't done the splines, definitely do that before riding it again, also check swing arm play and clearance. The swing arm has to be an exact distance between the pivot and frame, or the drive shaft will not line up properly. If it is loose, it might be moving when you lean over.
Are you sure it isn't the pegs dragging? The Vulcan will lean waaaay over for a cruiser, but the pegs will drag eventually. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
