2002 750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 05-24-2010, 05:43 PM Thread Starter
RITX
I have a chance to buy a used 2002 750 with approx 6500 mi cheap! It has a problem, the owner says there is a noise coming from the engine that sounds like a loose bolt. This happened while he was pulling out, he stopped and shut down. The engine runs fine, but when put in gear the noise begins. Had it checked out and so far can find nothing wrong on the left side of the engine.
Anyone know what the worst case scenario might be and worse case cost??
I can buy the bike for $700.00.
Thanks...............Rit.
Ritx is offline
post #2 of 20 (permalink) Old 05-24-2010, 06:20 PM
RaisingCain's Avatar
Send a message via MSN to RaisingCain
ACCT about a $50 to fix properly. Get a hold of TOC Manufacturing and get the MCCT kit and follow the directions!!! Sounds like a sweet deal have you read the Vulcan Verses and see what else you need to look for!
Mike "CoolMan" Cain
'96 750 "Able"
New Handlebars
Kuryakyn Grips
Kuryakyn levers
Kuryakyn offset highway pegs
Kawasaki Engine Guard
Bag stays
Cheap soft bags
Ear shave
MF Battery w/ tender
R/R
12V Outlet
Tank Bag
Sport Style tinted windshield
V&H Cruisers
Luggage Rack
To Do List:
New Tires next year
Hid lights
Front Brakes
RaisingCain is offline
post #3 of 20 (permalink) Old 05-24-2010, 06:23 PM
dirtrack650's Avatar
I'd buy it.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 20 (permalink) Old 05-24-2010, 09:22 PM
Calif Rider
weh44att's Avatar
I would say that if it does not make the sound untill putting it in gear and taking off, sounds more like the balancers. Acct's should make the sound any time the bike is running. Taking out the oil screen may give a Idea what is wrong.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #5 of 20 (permalink) Old 05-25-2010, 12:16 AM
flitecontrol's Avatar
Coffee grinder noise? Buy the bike. There are fixes for everything that has been mentioned
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #6 of 20 (permalink) Old 05-25-2010, 12:50 AM
The Professor
lance328's Avatar
Your ALL wrong!!! It's the final drive and shaft splines. Used parts from ebay and you got a good cheap bike. If you don't want it I'll take it and give you a couple hundred.
Did I fail to mention 2002-2004 were the years most common for the spline failure due to inadequate lube.
Your looking at $500.00 MAX but as low as $100.00 for good used parts.
Buy the bike and I will help you get the parts and gitter dun.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 20 (permalink) Old 05-25-2010, 07:04 AM Thread Starter
RITX
Thanks Lance, and everybody. I will let you all know what happens...........Rit.
Ritx is offline
post #8 of 20 (permalink) Old 05-25-2010, 09:05 AM
fergy's Avatar
I think Lance is right. And parts bikes are always coming available so I'd snag that bike in a flash. Check the spline lube procedure in my sig. It also has the steps for replacing what is most likely damaged on your bike. I was able to find the parts I needed used for around $100. Good luck!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #9 of 20 (permalink) Old 05-25-2010, 04:49 PM Thread Starter
RITX
2002 vn 750
Thanks to everyone for the advice. I have decided to pass on the deal. Talked to 2 mechanics who said that the transmission is the problem. Worse case will cost me in upwards of $2000.00. Can't swing that.
The bike is in N/W PA and still for sale. I can try to get the contact number posted if anyone is interested.
It has a Mustang seat, almost new rubber and decent bags + a windshield. If I had the time and skills I would buy it to part out.
Thanks again............Rit
Ritx is offline
post #10 of 20 (permalink) Old 05-25-2010, 04:56 PM
skalding's Avatar
Snort. The mustang seat alone might net you $300.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
