Electrical Short? Engine Cutting out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 05-23-2010, 10:27 PM Thread Starter
The last two days I have gone for a ride my VN750 it has began to act up once the engine has been ran at highway speed for about 10 minutes. The engine cuts out just for a brief second repeatedly over and over and backfires a lot. It really makes the bike jerk a lot and the tach needle jumps from 4-5K real erratic. I noticed tonight that when it starts happening if I turn on the turn signals it aggervates the problem. The turn signal indicator lamp also flashes real erratic rather than flashing smoothly. It almost seems as if there is an electrical short that is causing the problem. Also, after an episode of this when I get the bike home and park it for a few minutes the oil and neutal lights don't come on when I turn the key to on. The first time this happened I thought maybe a fuse had blown so I checked all the fuses and none were bad. I let the bike set for about an hour and then tried the key again and everything was fine. Anybody have any ideas on this one?
Rickt54 is offline
post #2 of 24 (permalink) Old 05-23-2010, 10:53 PM
ronbo43
ronnbo43's Avatar
have you checked the ground wires from battery to frame?
ronnbo43 is offline
post #3 of 24 (permalink) Old 05-24-2010, 09:47 PM Thread Starter
I did a quick visual inspection and they were tight and there were no visible signs of corrosion but I think I will take them loose and clean under the connections just to make sure. Thanks for the suggestion!
Rickt54 is offline
post #4 of 24 (permalink) Old 05-24-2010, 09:53 PM
The Professor
lance328's Avatar
Check all battery and ground connections but it sounds like the ignition switch is the problem.
https://www.vn750.com/forum/showthrea...gnition+switch
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 24 (permalink) Old 05-24-2010, 10:15 PM Thread Starter
I thought it might possibly be the ignition switch but the bike is an 05 with only 1600 miles on it that has always been in a garage and never ridden in the rain. I guess it could have some corrosion though. If the ground connections do not help then my next step is to dissasemble the IG Sw and clean it. Thanks for the suggestions!
Rickt54 is offline
post #6 of 24 (permalink) Old 05-24-2010, 10:23 PM
The Professor
lance328's Avatar
Since it is that new I would check All the connectors in the HL nacell and check the ignition switch connector by the neck.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 24 (permalink) Old 05-25-2010, 01:40 PM Thread Starter
HL nacell? I am kinda new here and don't speak all of the Vulcan lingo yet.
Rickt54 is offline
post #8 of 24 (permalink) Old 05-25-2010, 02:41 PM
fergy's Avatar
I think he meant to type headlight bezel or bucket. That's behind the headlight in the bucket where several electrical connections are made.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #9 of 24 (permalink) Old 05-25-2010, 03:42 PM
Rogue Warrior
Rogue's Avatar
It sounds like the ignition to me also. Could be a loose wire inside the "hockey puck", most likely the white wire that connects at 2 points.
Yup, you guessed it, I had that problem with mine.
'86 Vulcan 750
Sold Dec. 2010... after many enjoyable rides.
27K miles and going strong thanks to vn750.com !
Windshield, Deluxe Soft Grips, Vista Cruise Control, Leather Saddle Bags,
High Back Rest, Luggage Rack, Highway Brackets & Pegs, NGK plugs and wires.
Ignition Issue - Fixed! Replaced Hockey puck.
ACCTs- Grambo Trick worked!! TOC ACCT Springs installed!
Rogue is offline
post #10 of 24 (permalink) Old 05-26-2010, 10:00 PM Thread Starter
I checked and cleaned all of the ground points. I am going to tear into the keyswitch hockey puck this weekend. Everyting is dead as a door nail. I am thinking broken wire at the keyswitch. I will also check the connectors in the headlamp housing. Thanks to all for the advice!!
Rickt54 is offline
