PA inspection question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-23-2010, 11:52 AM Thread Starter
'86 VN750
vulcanpappy's Avatar
I'm in the process of making a set of highway pegs. I read on the PA inspection codes for motorcycles that:
"Code 175.160,(c)(4)Inspect the vehicle frame and reject if: (viii) The highway bars exceed the maximum width of 26 inches or are located more than 15 inches from the foot controls. "
Just wondering if any of you PA riders can confirm this before I continue fabrication.
Thanks
'86 VN750
CHROME-PLATED HANDLEBAR GRIPS
K&N Air filters
NGK Irridium plugs
Memphis Shades 17" Windshield
Front turn signal relocators
Customized Seat Modification
Custom Highway footpegs (inprogress)
vulcanpappy is offline
post #2 of 5 (permalink) Old 05-24-2010, 08:12 AM
I'm not sure what there is to confirm, you have the rule right there. Can you make the highway pegs removable?
LibertyPilot is offline
post #3 of 5 (permalink) Old 05-24-2010, 02:22 PM Thread Starter
'86 VN750
I'm sure I can, but what I was trying to check on is the 26" flipped up (stored position) or is 26" with pegs down (riding position). I'm probably sounding a little anal but why do all the work more then once?
'86 VN750
K&N Air filters
NGK Irridium plugs
post #4 of 5 (permalink) Old 05-24-2010, 03:18 PM
The Professor
lance328's Avatar
As long as your highway bar itself is not wider than 26" you will not have a problem. If you put pegs on the bar they must be 26" or less in the riding position.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 5 (permalink) Old 05-25-2010, 09:31 AM Thread Starter
'86 VN750
Thanks for the confirm Lance, that's sorrt of what I thought.
'86 VN750
K&N Air filters
NGK Irridium plugs
