A strange thing ! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 04-09-2006, 02:31 PM Thread Starter
Unhappy A strange thing !
Newbie in your forum, very soon a VN owner this week YESSSSSS!
The bike has a pb ! but what a wonderfull bike, i've already ride it !
In fact the starter seems running too slow, but the battery is new, in fact just put the 1st speed with clutch on , walk and press the starter button at the same time, it crank ! Strange thing no ? Could you help me to resolve this pb ?
some advices, some things to look about ?
Sorry for my poor English, I'm french and seems to be alone in france to have such this bike
thank's a lot
Lootux is offline
post #2 of 11 (permalink) Old 04-09-2006, 03:51 PM
hi lootux,
your english is probably better than most here in the US lol. from what you said, i take it you can jump start the bike. the starter being "slow" would bring me to the electrical system. first make sure the battery is fully charged and check all primary electrical connections make sure they are clean and no corrosion, especially the negitive ground. hopefully you have a maintance free battery.
good luck john
free wheel-e is offline
post #3 of 11 (permalink) Old 04-10-2006, 03:13 PM
Uber Member
if your battery is new... as mentioned above, see if its a mantinace free. if it is make sure your charging system is working fully. not sure bout over in france, but i know here you can take your battery to just bout any auto parts store and they will check it for ya.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #4 of 11 (permalink) Old 04-10-2006, 04:50 PM
welcome aboard, you'll love the site and the bike. Approximatly where in France do you live. I have visited several time and love your country.
accueillez à bord, vous aimerez l'emplacement et le vélo. Approximatly où en France vous de phase. J'ai visité plusieurs temps et aime votre pays.
Dasher is offline
post #5 of 11 (permalink) Old 04-10-2006, 07:07 PM
Uber Member
huh?
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #6 of 11 (permalink) Old 04-11-2006, 07:47 AM
Search Goddess
Dianna's Avatar
*L* Hizzo, he translated it above
translates to french as....
Now.. as far as starting the bike..
If it starts when you put it in gear and walk it, you may have a bad spot on your starter. Mine does this every once in a while. If I try and start it and it just clicks, I put it in 1st, rock the bike back and forth and then pull in the clutch, hit the button and Vrrroooom! she starts.
There are starter rebuild kits available, or sometimes a good cleaning helps.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #7 of 11 (permalink) Old 04-11-2006, 07:39 PM
now why didn't i think of that
post #8 of 11 (permalink) Old 04-11-2006, 10:49 PM
Search Goddess
Dianna's Avatar
*LOL* Cause you don't have a "flat" spot in your starter like I do? Doesn't happen often, but enough.. maybe once every ride or so.
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #9 of 11 (permalink) Old 04-13-2006, 04:29 PM Thread Starter
Red face Oups !
I was in Sweden for 2 days, so ...* sorry to be late !
fortunatelly by plane
in fact the worse weather I have seen ....
very windy, cold 3°C, and rain Brrrrrrrrrrrrrrrrr!!
I live near Lyon near the alps
the batt is new but I think a standard one, I will see it, I will pick it tomorrow
YESSSSSSSSSSSSSSSSSSSS!
The automatic translation is awfull, it's better to do not !!
When you say a bad spot : it means that there is a strong point just before crank ?
so like as if the starter force is not sufficient to turn the engine ? because it seems to be that !
The starter has been changed by another one wich was an used one but cleaned
and the same result.... I will make some tests more this we to see how it works exactly
Lootux is offline
post #10 of 11 (permalink) Old 04-14-2006, 11:31 PM Thread Starter
Talking Yessssssss
I ride yesterday with a very good weather, it was fine, except my ass which is not use to, just for now....
For the start pb, it seems that the starter doesn't get enough power !
I will check it, but I don't know exactly how !
I though to plug directly the starter on the battery (out of the bike) and check if it runs well (as fast as it needed)
will see
If you have some advices or somethings not to do ?
Lootux is offline
