Cruzing RPM - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 05-16-2010, 11:39 AM Thread Starter
KwisatzHaderach's Avatar
Cruzing RPM
I generally ride on slower roads with a speed limit of 25-30. When going this slow, what should my rpm range be? I usually keep it between 3-3.5K on the tach. Is this lugging the engine in third gear?
KwisatzHaderach is offline
post #2 of 11 (permalink) Old 05-16-2010, 11:55 AM
kay
carbon unit
kay's Avatar
Sound good to me until you start an up hill incline...then it's time to downshift and throttle up a bit. 3000 rpm keeps you charging a bit and keeps the coolant and oil pressure flowing good.
NOTE: for those of you who might be setting your idle speed low trying to make your engine lope and sound more like an HD....not a good idea....
2010 Triumph Speedmaster
1995 Vulcan750
1989 XT350
M880
1959 M38A1
kay is offline
post #3 of 11 (permalink) Old 05-16-2010, 12:23 PM Thread Starter
I was surprised to see in 3rd, when I hit a hill at 3K, the is plenty of pickup when I twist the throttle with no need to down shift. I just always try to make sure there is some engine breaking when I let off the throttle. On occasion, I get too slow and it does not slow much when I let off, that's when I grab a lower gear, and that's how a gauge my speed and rpm to gear setting.
post #4 of 11 (permalink) Old 05-16-2010, 05:22 PM
i pretty much keep mine around 3k. depending on the speed limit (eg. freeway). 3k is where I shift too.
post #5 of 11 (permalink) Old 05-16-2010, 06:22 PM
Mine stays around 5 to 5.5K rpm, ussually shift 4 to 5K rpm. Most my ride is out of town.
post #6 of 11 (permalink) Old 05-16-2010, 07:10 PM Thread Starter
I let mine wind up to 4.5K yesterday, and to my surprise it was as smooth as a sewing machine. I think I spent too much time off road on my Polaris Sportsman. That thing sounds like it could fly apart at any minute.
post #7 of 11 (permalink) Old 05-16-2010, 08:28 PM
Ron
Ron's Avatar
I ride mostly on the 4 lane. Tach indicates 4400 speedo 64 and GPS 60. That's with 100/90 front tire. Next tire change going with the 110/90 tire.
Ron
Ron is offline
post #8 of 11 (permalink) Old 05-17-2010, 09:11 AM
I usually let the road decide what gear I need. If I need 4th gear at 5k I make it happen. If I need 2nd at 3 I put it in. Most average I think I'm with you guys, about 3 to 3 and half - shifting around 4. I usually don't use first gear except for pulling away from a dead stop. If I'm heading around a slow corner I stay in 2nd gear. The rpm's might be a little bit low when going again but I engage the clutch real slow and keep the rpms as even as possible. Once I'm back around 3k I let the clutch lever all the way out...
LibertyPilot is offline
post #9 of 11 (permalink) Old 05-17-2010, 09:18 AM
My tach indicates exactly 4000 at an indicated 60 mph. I don't like to let it drop below 4000 during steady cruising. During normal use, out of town (not in stop and go traffic) I usually shift it at around 6000 at or near full throttle, up until just over the speed limit. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #10 of 11 (permalink) Old 05-17-2010, 10:45 PM
I read one guy who suggested for getting the maximun life, and least wear and tear on an engine to keep your revs between 20% and 80% of your redline. So for the vn750`s redline of 8500 rpm, that would translate into 1700 to 6800 rpm while riding. That`s almost 100 mph at the top end.
