Cleaning Help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-14-2010, 04:20 PM Thread Starter
Outgrowthmusic.com
Cleaning Help
Just bought a 94 VN750. It was not garage kept and has light weathering on the rims. Any suggestions on getting these to look like new again??
Outgrowth is offline
post #2 of 9 (permalink) Old 05-14-2010, 11:38 PM
simple green and some wd40. scrub, rinse, repeat
post #3 of 9 (permalink) Old 05-14-2010, 11:57 PM
Love My Baby
rubyrick's Avatar
THIS is a fantastic product to clean your rims, chrome, aluminum and stainless parts. Works great on fiberglass, too. It's called Star-Clean one-step metal treatment. Easy application and I highly recommend it. Directions say NO BUFFING NEEDED but for difficult rust or other stains I found lite elbow grease really did the job. Incredible restoration and shine.
I paid $20 for a tube at the website in my link above, and West Marine sells it for $29, so don't get it there!
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #4 of 9 (permalink) Old 05-15-2010, 12:09 AM
dirtrack650's Avatar
Mag wheel cleaner and a pressure washer. BonAmi is great stuff too.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 9 (permalink) Old 05-15-2010, 01:41 AM Thread Starter
Outgrowthmusic.com
Thanks guys! After a little more inspection - it is looking worse than I thought.. pitting. It is not terribly deep, but ins't the only way to get this off by steel wool or some other abrasive?
post #6 of 9 (permalink) Old 05-15-2010, 02:27 AM
The problem with the Vulcan's rims is that they are clear coated. If the coating is damaged, it cannot be repaired, and will have to be removed. Aircraft Remover should take it right off, but you will need to remove the wheels and tires before using it. It may be impossible to completely restore the wheels back to new condition if there is severe pitting. If that is the case, I would consider removing the clearcoat, and having them powdercoated. You could have them done in silver, which would closely resemble stock, or you could go for some other color entirely. If you have lots of money, you could even have them chromed. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #7 of 9 (permalink) Old 05-15-2010, 05:07 AM
KIMMERLING's Avatar
how much would chroming cost?
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #8 of 9 (permalink) Old 05-16-2010, 02:32 AM
Look online or in yellow pages for a local chrome shop. Well I guess local in Texas is a relative thing, and could be a few hundred miles away. <G>
post #9 of 9 (permalink) Old 05-16-2010, 11:30 AM
More chrome means more cleaning, polishing, and when chrome is dirty, not good. Powder coat the wheels with a color that compliments your tank - looks great and easy to keep clean.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
