Odometer Accuracy - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 05-01-2010, 11:48 PM Thread Starter
Columbus, Ohio
jimkonst's Avatar
Odometer Accuracy
I read in the May 2010 Rider Magazine Tech Q&Q that our inaccurate mechanical speedometers are independent from our mechanical odometers, and so the odos should still be accurate. The guy, Chirs Sidah, who writes the column, says that the only variable is wheel diameter. So, if you are trying to figure your VN750 gas mileage, the odometer will accurately allow you to do that, but if you want to know your speed, you are on your own.
I guess that also means that if you swap tires to make the speedo accurate, you will screw up the odometer.
Digital speedometers are a different matter, and both speedo and odo are run by the same mechanism, so this does not apply.
Chris did not specifically mention the VN750.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #2 of 20 (permalink) Old 05-02-2010, 02:00 PM
What is a speedometer?
post #3 of 20 (permalink) Old 05-02-2010, 05:29 PM
A fairly useless device.
post #4 of 20 (permalink) Old 05-02-2010, 05:32 PM
That little thingy that tells you when you are in ticket range.
post #5 of 20 (permalink) Old 05-02-2010, 06:05 PM
Chavisimo's Avatar
Its on page 3 of the driver's safety manual. Says the speedometer is the first thing you look at when you see blue lights.
VROC Number: 31246
2003 Kawasaki VN750 SOLD
2006 Honda VTX1800C
Chavisimo is offline
post #6 of 20 (permalink) Old 05-02-2010, 08:09 PM
Serves approximately the same purpose as a rear view mirror in an Italian sports car. <BG>
post #7 of 20 (permalink) Old 05-03-2010, 08:12 AM
MANIC MECHANIC
vulcanjoe's Avatar
i thought the speedometer was everyone next to you roll with the flow and you should be ok.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #8 of 20 (permalink) Old 05-03-2010, 08:24 AM
Its that thing that looks like a fan blade when I'm pulling onto the highway...
LibertyPilot is offline
post #9 of 20 (permalink) Old 05-03-2010, 09:32 AM
GIMPYRDR's Avatar
Answers some questions Jim. I went riding last Wed. and passed thru a school zone with a show-your-speed radar. Per our PM's, the speedo was right-on and your above post would account for the loss of mpg.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #10 of 20 (permalink) Old 05-03-2010, 12:07 PM
Only if you are not out of state, if you are out of state, you are the example...lol...
Been a looong time, and they sure have gone up $175, ouch...
