what coolant and drive oil to use? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 04-24-2010, 05:24 AM Thread Starter
Headbanger/Popes of Hell
ruger's Avatar
my vn750 is a little low on coolant and just wanted to know what kind I should get/use?
also, I will be replacing the rear tire soon and lubing the splines. and while I'm doing all that I thought I'd change the drive oil too. so what kind of oil should I get/use?
thanks.
ps. yeah, I know. I could've done a search on this, but I'm lazy!
ruger is online now
post #2 of 24 (permalink) Old 04-24-2010, 10:18 AM
dirtrack650's Avatar
I've been told by a local repair shop that has nothing to do with a 'stealership' to always use a coolant that is compatible with aluminum and includes a lubricant for water pumps. My GL500 is a good example: to change the water pump in that engine, you must drop the engine split the cases!
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #3 of 24 (permalink) Old 04-24-2010, 10:23 AM
Ouch DT, please tell me it aint so... I don't want to split the case on my CX500... (same engine)... but then again I might not own it long enough to have to worry, thinking about selling the CX to cover costs of an engine rebuild on the Jeep.
post #4 of 24 (permalink) Old 04-24-2010, 10:30 AM
Slim the CX/GL models make great looking 'sport / touring' bikes. They were ahead of their time in design, a wonderfully built solid engine all the way up to 10k rpm. Check your valve tappets (can you believe it's a push rod engine?), clean the carbs, always check your coolant level before each ride, and you should be good to go. Add some sport bike bars (some folks call them super bike bend) lower the seat, add a small faring and it's a fun ride. The only design problem is it's tall in the saddle when stopped, but the foot peg / seat height are for short legs - go figure.
Here's a pic of my 500 while on a 700+ mile trip - just a little outing on a GL:
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #5 of 24 (permalink) Old 04-24-2010, 12:39 PM
also, I will be replacing the rear tire soon and lubing the splines. and while I'm doing all that I thought I'd change the drive oil too. so what kind of oil should I get/use?thanks.
Like DT said "always use a coolant that is compatible with aluminum and includes a lubricant for water pumps." and I would add to it, at least have a 50/50 mixture if not a bit stronger as the boiling point will go up quite a bit on a good strong mixture, plus it will be stout enough that if in an emergency you need to, you can add a bit of water...
On that last question "change the drive oil"...???
Well, its not a Hardly because you need anti-freeze, I'm stumped if you don't change it with the engine...
Someone help him here, my CRS must be worse than I thought...
post #6 of 24 (permalink) Old 04-24-2010, 01:04 PM
I am guessing here you mean "final drive oil" that goes into the rear hub.
I would use any synthetic gear oil within the 70w-120 range.
I am using Mobil One 75w-90 now , but have used Supertech synthetic gear oil also.
The manual calls for a 90w "hypoid gear oil" but EVERYONE uses synthetic gear oil now because it aint that much more expensive, and it is just simply better.
I am surprised you have not changed the final drive oil before. On a used bike it's the one of the first things to do and on a new bike it should be done with the first engine oil change.
Any coolant that says "safe for aluminum" is fine to use. Buy a bottle of distilled water to make a 50/50 mix, DO not fill over the full line, as it will just overflow when the bike gets hot.
post #7 of 24 (permalink) Old 04-24-2010, 01:06 PM
C'mon ruger, you know where to go.... All this info is in the Versus
km60155 is offline
post #8 of 24 (permalink) Old 04-24-2010, 02:20 PM
I am using Mobil One 75w-90 nowKM
Thats what I used, I remembered the Mobil 1 but couldn't remember the 75w-90 part... I always changed at every oil change, shucks it didn't hold hardly any, so why not...
Thank KM, you got my CRS streightened out...lol...
post #9 of 24 (permalink) Old 04-24-2010, 05:46 PM
Amsoil Man's Avatar
Ruger: Here is testing showing the GEAR LUBE product ,tested against all respectable products that talked about in our forum. Thanks for looking the products on the market TESTING and of course make an educated opinion/choiceof what products to use.
http://www.amsoil.com/lit/g2457.pdf
They also make coolant with a sealing agent and a wetting agent.
Amsoil man
Pick ups reset
Splines lubed
Kenda Kruz tires 110Frt. / 170 rear
Custom saddle seat
Backrest
1500 classic rear fender
Cobra slants /Custom Made turndowns
Diamond Plate Buffalo Leather Bags
Throttle lock
Front bearings repacked
Front shock oil replaced
Led bulbs
Amp meter
Running Boards
Dial A Jet Carb settings
Gremlin Bell (front mount)
Fully Lubed with Amsoil Lubricants
Trailer hitch / Hidden
Your Local AMSOIL Connection! Cell#989-329-1225
Amsoil Man is offline
post #10 of 24 (permalink) Old 04-25-2010, 10:04 AM
93VN750's Avatar
If you live in a climate that does not see freezing temps, I would use deionized water and a water wetter such as Red Line.
More better cooling properties than any glycol mix.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
