Difficulty starting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 33 (permalink) Old 04-22-2010, 04:18 PM Thread Starter
Mac84's Avatar
Difficulty starting
Today I had trouble starting. Seemed to have the most trouble when the bike was warm. I started the bike this morning just fine, rode it to class, no issues. Went to my one hour class and when class was over, I couldn't get it to start. It finally started when I gave it some choke AND some gas (even though the engine was warm according to the temp gage) that finally seemed to get it to fire up. Rode it from school to run some various errands. Each time, to get it to start, I had to open the throttle completely as far wide open as it would go. It wouldn't want to fire up otherwise. Once, it seemed like the battery was going to die, as it struggled just to turn over. But ever since that one time, it has turned over just fine, but wouldn't start unless I gave it full throttle.
I will continue to see if I can find any patterns, but so far it seems like sometimes it fires up just fine, and other times, not so much.
I do have a MF AGM battery, recommended to me by lance. it's a DEKA. I have iridium spark plugs as well.
2006 VN750 acquired March, 2010, 19,544 miles
Currently 20,147 miles (5/1/2010)
Splines lubed
R\R relocated
Deka MF AGM ETX15L
Iridium spark plugs
Pirelli MT66 tires 110 front 150 rear
Speed bleeders
Mac84 is offline
post #2 of 33 (permalink) Old 04-22-2010, 04:35 PM
ronbo43
ronnbo43's Avatar
try putting some sea foam in the fuel the vn750 seems to like that stuff
ronnbo43 is offline
post #3 of 33 (permalink) Old 04-22-2010, 04:44 PM
How old is the battery?
Have you checked the voltage lately?
Try putting it on a battery tender overnight, and see if it starts any better during the day when it is warm or hot.
Is the starter draggy at all when the battery is fully charged.
Check the plugs for color or if they are wet.
Practice a bump start. <G> Sorry, but that`s the method of last resort.
post #4 of 33 (permalink) Old 04-24-2010, 09:29 PM
Duffer's Avatar
hard start
Talked to a fellow club member who has been riding an 87 for many years. He says a lot of VN750s are hard starts.
Duffer
VROC #26950
Canadian Motorcycle Cruisers Chapter 079
York Region, Ontario
Duffer is offline
post #5 of 33 (permalink) Old 04-24-2010, 09:54 PM
Love My Baby
rubyrick's Avatar
Normally I have the best starts when I put the choke on full and press the ignition switch without giving any gas at all. Hold the switch down until you get full start, not just the beginning of a start. It's only for three or four seconds, not enough to hurt your starter or ignition, but it should ensure an easy start.
Once the engine starts to rev beyond 3000+ rpm's, I back down on the choke to keep the rpm's at just under 3000. This keeps the rattle down as well. Good idea to let the oil circulate a bit before actually putting your bike in gear, and I usually lower the choke and rpm's to no more than 2000 just as I put it in first gear. That keeps the clunking down!
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #6 of 33 (permalink) Old 04-26-2010, 06:18 PM Thread Starter
Mac84's Avatar
Battery is 2 weeks old.
I just checked the voltage. 13.1V when the bike is off. 14.2V when it is revving at 4,000 rpm. What do ya'll think about that? good? bad?
One thing I noticed is that when I released the throttle (after holding it at 4,000 rpm), the Voltage jumped up to 14.6V for a split second before settling down back to 13V.
I'll try charging the battery sometime soon, and see if it starts better.
But it just feels like the motor has to turn over way longer than it used to before it'll fire up.
Splines lubed
R\R relocated
Deka MF AGM ETX15L
Iridium spark plugs
Speed bleeders
Mac84 is offline
post #7 of 33 (permalink) Old 04-26-2010, 06:29 PM
dirtrack650's Avatar
Try no choke and no throttle on your hot starts.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #8 of 33 (permalink) Old 04-26-2010, 07:04 PM Thread Starter
Mac84's Avatar
DT
I don't normally use choke on hot starts, just did it that one time to see if I could get it to start at all. But I will try not using any throttle on hot starts and see what happens.
Splines lubed
R\R relocated
Deka MF AGM ETX15L
Iridium spark plugs
Speed bleeders
Mac84 is offline
post #9 of 33 (permalink) Old 04-26-2010, 08:11 PM Thread Starter
Mac84's Avatar
Today my bike acted like it was running out of gas well before I would normally need to switch it to reserve. The meter wasn't on Empty. I switched it to reserve anyway, and went to the nearest gas station and topped it off. It only took 2.28 gallons to fill up which means it still had 1.32 gallons in the tank.
Splines lubed
R\R relocated
Deka MF AGM ETX15L
Iridium spark plugs
Speed bleeders
Mac84 is offline
post #10 of 33 (permalink) Old 04-27-2010, 02:50 AM
I have had this happen to me on several different bikes over the years.
Your carbs need to be cleaned because it sounds to me that the pilot jets are plugged.
The hole in these jets are VERY small and it's easy for them to get plugged up.
The "give away" symtom is when you said you had to give full or nearly full throttle and even choke.
Maybe this magic Seafoam just may work to clean them. It would be a good test for this stuff.
I never heard of Seafoam before joining this site and from what many have said.......I guess it does work.
honest Al is offline
