two questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-20-2010, 05:25 PM Thread Starter
two questions
First what size handlebars dose the vn750 take? and second how do you go about eliminating the back rest on the back seat? I see some people without and it looks much cleaner. Thanks in advance
IanH is offline
post #2 of 4 (permalink) Old 04-20-2010, 06:18 PM
# 1. 7/8" bars
#2.You have to modify the stock seat or buy a different seat such as a meanstreak has or a some have used a harley seat the stock seat bolts to the backrest. You can also do away with the aluminum fender struts.The fender is supported by the frame tabs.
post #3 of 4 (permalink) Old 04-20-2010, 06:59 PM Thread Starter
how do i bolt the seat down if i get rid of the back rest
IanH is offline
post #4 of 4 (permalink) Old 04-20-2010, 07:09 PM
I modified my seat and cut off the backrest section of it, reshaped the foam and added tabs on each side that the fender bolts go through before i recovered it. If you pick up a harley seat or some other seat with the tab sticking out the back you drill a hole in the fender from the top and bolt it down that way .Click on my username and go to my profile and look at the different pictures of my bike and you can see how it will turn out,I shoulda documented the seat modification process,but did not think of it at the time.
