Penetrating Oil - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 04-14-2010, 04:16 PM Thread Starter
Columbus, Ohio
jimkonst's Avatar
Penetrating Oil
We were discussing whether WD40 is a penetrating oil. Then I received this from an aviation source.
For all you Gear Heads, review the below Test Results of
various Penetrating Oils for some interesting and useful tips
Penetrating Oils Compared
Machinist's Workshop magazine actually tested penetrates for break out
torque on rusted nuts. Significant results! They arranged a subjective
test of all the popular penetrates with the control being the torque
required to remove the nut from a "scientifically rusted" environment.
Penetrating oil ..... Average load
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ..............214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix... 53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
transmission
fluid and acetone.
Note the "home brew" was better than any commercial product in this one
particular test. A local machinist group mixed up a batch and all now
use it with equally good results. Note also that "Liquid Wrench" is about as
good as "Kroil" for about 20% of the price.
Jim
'95 Kawasaki Concours
Sold my Vulcan
I do LOTS of dumb stuff. Riding is only one of them.
jimkonst is offline
post #2 of 7 (permalink) Old 04-14-2010, 04:26 PM
MANIC MECHANIC
vulcanjoe's Avatar
If i can i prefer to use a smoke wrench on rusted bolts.
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #3 of 7 (permalink) Old 04-14-2010, 07:43 PM
I have mostly used Kroil, as it is darn good and made in Nashville, and pretty cheap, it also goes a long ways on the small stuff I usually use it on, I will also vouch for Liquid Wrench being about as good, WD-40 has another name also "Gunsmith's Friend" because of the hard gum like film that it leaves which will cause problems with most guns and they will have to be broken down and seroiusly cleaned, never ever use it on a trigger...
One of the better things to use on a serious target trigger to clean & lube is "Ronsonol" lighter fluid...
post #4 of 7 (permalink) Old 04-15-2010, 09:59 AM
thom1's Avatar
no marvel mystery oil?
<- Tom (me)
05 VN750 Sinfully stock
thom1 is offline
post #5 of 7 (permalink) Old 04-15-2010, 10:54 AM
I am a fan of Liquid Wrench too. The flammable one in the yellow can works great.
MarkinMichigan is offline
post #6 of 7 (permalink) Old 04-15-2010, 11:29 AM
Interesting results. Looks like I may have a use for that 1/4 bottle of ATF sitting in the garage!
post #7 of 7 (permalink) Old 04-15-2010, 07:39 PM
the best i ever used is rust check
bunyan is offline
