Problem going over 30 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 04-06-2010, 01:35 PM Thread Starter
supasamurai's Avatar
I just woke my bike up after the winter and it's having a really hard time getting up over 30. It seems to rev up just fine when it's not in gear, but when it is in gear, it bogs down if I try to go over like 3k rpms. I suspect a vacuum problem, maybe the tranny is a vacuum assisted type or something and when it's in gear it's running into a vacuum leak somewhere? Anyone had a problem like this before?
supasamurai is offline
post #2 of 18 (permalink) Old 04-06-2010, 04:02 PM
Issues with poor running after a winter lay up are not uncommon, especailly for North Amrican riders. It is most likely to be some form of dirt or contamination in the fuel supply somewhere (what do they put in your petrol over there?). Prevention is always better than cure but having not done that the best/easiest solution without taking the bike to pieces appears to be an application of Seafoam as directed on the can.
Mine is a Red one.
Colour matched Bungee straps
essexboi is offline
post #3 of 18 (permalink) Old 04-06-2010, 04:08 PM
flitecontrol's Avatar
Did you put fuel stabilizer in the gas and let it get into the carbs before you parked it?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 18 (permalink) Old 04-06-2010, 04:17 PM Thread Starter
I am seafoaming, yes. Also, it had the same problem before I parked it. I bought it used and without a carburetor, so I put a new (used but freshly rebuilt) carb in and then parked it. So why does it stumble when I'm in gear, but not when I'm in neutral?
post #5 of 18 (permalink) Old 04-06-2010, 04:38 PM
Assuming it is a fuel problem then it will be a simple matter of the volume getting through, or not. When not in gear the engine needs very little fuel to run so a small restriction may not even show. As soon as you start to load the engine the amount of fuel you need rises dramatically and any problems with delivery will soon appear.
Now we know you have "been at the carbs" it becomes even more likely that this is your problem. If the Seafaom does not cure it then you will be looking at things like your vacuum hoses and various other fittlngs to make sure everything is on correctly and there are no kinks in the bends or leaks at the joints. After that it may be time to start taking it apart but for now just make sure as best you can it is together in the way it should be.
Have you made any of your own pipes and hoses for it or did you use stock parts?
Mine is a Red one.
essexboi is offline
post #6 of 18 (permalink) Old 04-06-2010, 09:58 PM Thread Starter
Humm, could it be the cheap lawnmower fuel lines i used to replace the cracked stock ones? I wonder if they're just collapsing when i gas it.
post #7 of 18 (permalink) Old 04-07-2010, 12:43 AM
Have you checked the air filters?
Might not be that there's not enough fuel, but too much air if they are disintegrating/old.
post #8 of 18 (permalink) Old 04-07-2010, 09:10 AM
It may be.
I once had an old VT500 which I commuted into London every day. Bits wore out and I got it a new(??) set of carbs from a CA spec bike and after messing about taking all the rubbish off reassembled it but had to make some new fuel pipes from my bits box. The bike ran with no problems at all unless I wanted to go over 50 for more than a mile, at which point it would act like it was running out of fuel. Slowing down to 40 for a few seconds cured it but as soon as I went over 50 again the problem would reappear.
It turned out that I had cut one pipe a quarter of an inch too long and when I bolted everything together a small kink would happen. Not enough to stop it running at urban speeds but just enough restriction in the fuel flow to make higher speeds an issue. It seems I am not the only one this has happened to, so check yours carefully. It may well be just a quarter of an inch too much tube in the wrong place.
Mine is a Red one.
essexboi is offline
post #9 of 18 (permalink) Old 04-07-2010, 04:55 PM
bj31702's Avatar
Send a message via Yahoo to bj31702
Just throwing something out there. Have the carbs been sync'd?
'09 Nomad e sold
'85 VN700 A1 (needs work)
'11 Voyager
bj31702 is offline
post #10 of 18 (permalink) Old 04-07-2010, 05:12 PM
Is the Carb. vent line cut on a 45* into the filter box, could it be jambed in and blocked...?????????
