Do i need all new cables ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-05-2010, 09:24 PM Thread Starter
Send a message via Yahoo to jdamato1
Just changed my handlebars to a lower profile. The clutch cable is to long. I will replace it with a nice shiny one that is 4 inches shorter, ( no big deal ) My problem is the throttle tube doesnt return to closed now when I twist it. It twists easy but wont decelerate. Can I adjust it or do I need shorter cables for that too ?
jdamato1 is offline
post #2 of 6 (permalink) Old 04-05-2010, 10:34 PM
The Professor
lance328's Avatar
Try lubing and adjusting first, if you need to shorten Motion Pro can custom make them.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 6 (permalink) Old 04-05-2010, 10:41 PM Thread Starter
Is there an easy way to adjust them ? I read the clymers version but was a little lost.
jdamato1 is offline
post #4 of 6 (permalink) Old 04-05-2010, 10:48 PM
The Professor
lance328's Avatar
There are adjusters top and bottom of the cables, if there is not enough slack in the cables the throttle will not return easily.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 6 (permalink) Old 04-06-2010, 06:18 AM
If the cables are too long, they shouldn't do anything but not look good. It's when they are too short that you run into problems. Unless you zip tied them in place to hide the extra length. In that case they might be binding. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 6 (permalink) Old 04-06-2010, 09:39 PM
Check that you did not slide the throttle too close to the bars. This would cause a drag on the return action.
Also check that the throttle grip in not mounted too close to the throttle. This will also cause a return problem.
Also make sure that there are no sharp bends in the cable.
honest Al is offline
