Old school thinking - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-28-2010, 09:34 PM Thread Starter
Old school thinking
I was taught that as long you had compression, spark and fuel your motor would run...maybe not well, but run. Me experience with Vulcans (I have owned 2 1500's) is that they will not start unless the battery has a full charge. I have 140psi compression. I have a full charge on the battery. I put a tester on the plugs (all 4)to check for spark. The bike ran for about 15-20 seconds. Shut the bike off. It refuses to give me even a cough. What am I missing? I do not have enough experience with ignition boxes to trouble shoot them. A friend suggested bad coils but both going bad at the same time? Please Help...Cosmo
Cosmotg is offline
post #2 of 10 (permalink) Old 03-28-2010, 10:03 PM
How about the ignition switch. Try wiggling the key.
post #3 of 10 (permalink) Old 03-28-2010, 10:10 PM
second motion on the iggy switch... its a common problem with our bikes. Another comon problem is the stupid side stand switch...
post #4 of 10 (permalink) Old 03-28-2010, 10:36 PM Thread Starter
I must have left something out. The starter turns and I am getting spark. I checked the kickstand switch and the ignition switch. As a matter of fact I checked all safety circuits. If I had a problem with the ignition switch would the starter still turn and would the coils still send spark to the plugs? Please explain....Thanks Bob
Cosmotg is offline
post #5 of 10 (permalink) Old 03-28-2010, 10:49 PM
ok nm... If you have good spark, then that rules out the iggy switch, saftey switches and kill switch. Wouldn't be coils if you have spark. hows the fuel flow? kinked Vacuum line from carb to tank, fule lines good, are the carbs full of fuel?
post #6 of 10 (permalink) Old 03-28-2010, 11:25 PM
lostboy1975's Avatar
check the safety switch behind the clutch lever. mine went out last year and i played hell trying to figure it out.
lostboy1975 is offline
post #7 of 10 (permalink) Old 03-29-2010, 02:32 AM
This problem will cut out the spark as well as the side stand switch and neutral safety switch, emergency kill switch and all the other safety devices on the bike... This problem almost has to be Fuel related. Spark is Good, Compression is Good, then next would be Fuel... although...how do those air filters look?
post #8 of 10 (permalink) Old 03-29-2010, 08:39 PM
Ok, just for reference, you are missing something. It takes FOUR things to make an engine run. Fuel, compression, and a spark AT THE RIGHT TIME. Your ignition timing has to be pretty close. A spark during the exhaust stroke is pretty worthless, even though a lot of engines have one.
But those are just the basics. It gets a lot more complicated. You have to have almost exactly the right air/fuel mixture, a really good spark (at the right time), the starter has to turn the engine over fast enough, ect. Some engines are very temperamental about starting, because their design puts them on the outer margins for what is needed to start and run, so there is no room for any errors, everything has to be perfect. Other engines are much better designed, and have more room for variance.
My new EX500 starts so fast you never even here the starter. My Vulcan 750s, both of them, have to be turned over several times before they will start, and have always been that way, since new. I will try the iridium plugs next time I change them, but spark, compression, air/fuel, and timing seem to be fine. But, that is checking the spark outside the engine. It may not be nearly as good under compression.
Also, I have always removed the clutch and sidestand switches from every single bike I've ever owned that had them, after having had one fail. I leave the engine cutoff switch, but if it failed, I would probably not replace it. I have never needed one on a streetbike. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #9 of 10 (permalink) Old 03-29-2010, 08:53 PM Thread Starter
Your right! Got the bike started and running for about 30secs today. Looks like the starter is drawing a lot of amps. I will take it off and have it tested tomorrow. Also found a wire (Black/Yellow) in the harness not hooked up. I posted a picture in the electrical section because I can not find where it goes. I am encouraged that it runs and will try to eliminate problems until it runs right. Timing of course may be another issue but since it sounded good. Thanks for the input...Cosmo
Cosmotg is offline
post #10 of 10 (permalink) Old 03-30-2010, 07:02 PM
There is a black/yellow wire for a ground running to many electrical components on the bike.
