Am I The Only One??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 27 (permalink) Old 03-21-2010, 09:45 AM Thread Starter
Gemguy's Avatar
Question Am I The Only One???
Had this Vulcan 4 years and a 500 V many years before. The kickstand is fine until the bike rocks forward about 3 inches and then it collapses. Has anyone figured a fix or solution to this highly unstable situation? It's not like you can take off with the thing down (if your switch is working) but I wish there was a way to make it more stable. Anyone come up with any ideas???
~VROC~ # 389
Gemguy is offline
post #2 of 27 (permalink) Old 03-21-2010, 09:57 AM
Crobins365's Avatar
I usually use the centerstand and keep the sidestand down (when parked) as a backup option.
C
Crobins365 is offline
post #3 of 27 (permalink) Old 03-21-2010, 10:57 AM
IMBoring25's Avatar
I generally park in first. If parking on a noticeable downhill slope, I shut the engine off, let the clutch out, and gently ease the bike onto the transmission before putting the stand down.
If your concern is while duck-walking it around the garage, I just put the stand up and don't use it.
IMBoring25 is offline
post #4 of 27 (permalink) Old 03-21-2010, 11:57 AM
dirtrack650's Avatar
My VN crashed in my garage due to side stand. Really pissed me off...
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 27 (permalink) Old 03-21-2010, 12:40 PM Thread Starter
Gemguy's Avatar
Thanks guys. I leave it in gear on an incline too but in my garage it's inconvenient.
Cin, I find it not so easy to put it on the center stand and if it comes forward off that stand the center won't help you at all because the bike will be rolling forward and the side stand will easily collapse. I wish they had made it lock forward a little more so you'd have to lift the bike a little to let it fold back, but they didn't. Wonder if putting a bend in it would help.
~VROC~ # 389
Gemguy is offline
post #6 of 27 (permalink) Old 03-21-2010, 02:03 PM
Warning--Don't mess with that kickstand unless you understand what you are doing...
One of the switches on my 06 (best of 3 I have owned) failed and cost me my bike and a bad shoulder... I bought another 06 but it was not 1/2 as good a the one I crashed, so I traded it for a new Sportster, I still miss the one I wrecked...
post #7 of 27 (permalink) Old 03-21-2010, 02:23 PM
So you are saying that the sidestand won't work for you because you keep bumping the bike forward and knocking it off the stand?
Sounds to me like you need to clean your garage out and just watch what the hell you are doing while the bike is in there...cause the problem seems to be your clutzyness and not a problem with the stand itself. (no offence meant here, I have gone one step worse myself and let my bike fall because I did not check to see if the stand was completely folded out before leaning her over)
You could try hooking a bungee cord to to sidestands foot and wrapping it around the front tire or fork, but I think just being carefull is a simplier solution.
I have yet to knock my bike over, but also think perhaps buying or making a wheel chuck might help with your problem. Or one of those rolling bike stands.
like this:
https://www.wheeldock.com/
or this:
http://motorcycledolly.com/
or this:
http://www.thebikepal.com/index.html
Video:
http://www.youtube.com/watch?v=1N2KdXHejMM
I do give you credit for admiting your clutzyness...
post #8 of 27 (permalink) Old 03-21-2010, 06:33 PM Thread Starter
Gemguy's Avatar
Thanks Old Dog I've had other thoughts of what to do.
Easy there KM I'm not that big a clutz and the garage is pretty clean. It's just when I am maneuvering the bike to back it up between the shelf and my wife's car I often have to move it and reposition so it doesn't interfere with her opening the door to the car and it's out of the way so we can move in and out of the house.
What occurred to me is if I can fasten a piece of steel as an extension (shoe) extending from the bottom of the stand forward when it's down, it will force me to straighten the bike up to fold the stand. That may prevent accidental fold up. All thoughts welcome.
~VROC~ # 389
Gemguy is offline
post #9 of 27 (permalink) Old 03-21-2010, 07:42 PM
flitecontrol's Avatar
FWIW, I'm a klutz too, and a slow learner to boot. But I'm not going into detail!
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #10 of 27 (permalink) Old 03-21-2010, 07:58 PM
The Professor
lance328's Avatar
Put in first gear and use double sided velcro to cinch the brake lever to the grip. Now you have a parking brake.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
