Seat modification - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-11-2010, 01:01 PM Thread Starter
Seat modification
Is there a way to lower the original seat half to one inch on my 86 vulcan or do I need to replace it? I would like to have my feet flat on the ground. Thanks for any info.
PR_V_rider is offline
post #2 of 10 (permalink) Old 03-11-2010, 01:34 PM
There are several members who have modified their own seats by removing the cover, shaving some foam, adding different foam or gel pads, and re-stapling the cover back on. Go down to the "Equiptment" forum and look through past threads, or do a "Search" on various combinations of words like: seat, lowering, modifying, customizing, etc.
Check out slimvulcanrider and a recent thread where he is building his own seat, and has lowered it and moved the seating position back several inches.
There are also seat customizers who will do the work for you.ie. www.buttbuffer.com
Here is a magazine article by a rider who is vertically challenged too, and had buttbuffer re-contour her mc seat with one of their pads.
http://www.buttbuffer.com/roadblock.asp
post #3 of 10 (permalink) Old 03-11-2010, 04:49 PM
Big Dumb Viking
asbrand's Avatar
Send a message via AIM to asbrand Send a message via MSN to asbrand Send a message via Yahoo to asbrand
I am using http://www.meancitycycles.com/ to get my seat modified. Friend of mine's father uses them and swears by 'em.
-Az
http://www.asbrand.com
1989 Kawasaki Vulcan 750
Upgrades so Far:
Analog Voltmeter
PFIII Windshield
RAM GPS Mount w/Garmin GPS
Cigarette Lighter Power Adapter
Saddlemen's Classic Explorer Seat
Pro-Tac Driver's Backrest
LED Tail Light
LED Rear Turn Signals
Luggage Rack
Storage Trunk
Engine Guard w/Highway Pegs
Radiator Grill Cover
Turn Signal Relocation Bracket
Saddlebags
Floorboards
asbrand is offline
post #4 of 10 (permalink) Old 03-11-2010, 05:06 PM
dirtrack650's Avatar
This pic is from user Denny6006:
I really like the way he did his seat. Nice job Denny...
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 10 (permalink) Old 03-11-2010, 05:14 PM
. . "Boricua" Rider . .
kawabengie's Avatar
If you just want to lower it one inch, maybe you could do it yourself as I did (check link down)
https://www.vn750.com/photopost/showp...o=1408&cat=584
You'll need a screwdriver, sharpie, electric knife, and hand stapler gun and a couple hours of work and youre done.
Good Luck,
BnG
(I'm curious about your avatar name. Do the PR stands for Puerto Rico? If so, maybe I could help you in your mission . . . -I live in Dorado-)
'94 Special VN750; custom solo seat, xlx handlebars, flame grips & mirrors, Screamin' Eagle II slip on mufflers, S/S 2" lowering brackets, Highway Hawk double oval blue headlight and driver kury flame floorboards, highway bar w/ E. Trotta's pegs, chrome engine, rad and neck covers, chrome covered cables, chrome stebel horn (never enough chrome!), hidden blue LED's, Clear Alternative's LED tailight, custom chrome tailight license plate w/ LED's.
Soon: LED voltmeter & passenger kury flame pegs.
kawabengie is offline
post #6 of 10 (permalink) Old 03-11-2010, 08:47 PM
DT
Thanks DT ,and kawabengie looks like he took the same approach,his link shows how to do it .If the OP wants to tackle the job.
post #7 of 10 (permalink) Old 03-12-2010, 08:13 AM
On His Lady Vulcan
wkrizan's Avatar
Or one can take an easier aproach and use shorter shocks (Dyna 11.5") A little more pricey than just shaving the foam but it kills two birds with one stone. Gets you to sit flat footed and puts a better shock on the bike, cause as we all know the OEM shocks on these bikes suck.
Pictures of the "Ladies"
wkrizan is offline
post #8 of 10 (permalink) Old 03-12-2010, 09:10 AM
Send a message via Yahoo to luigit
lowering
thats just what i did on my restoration except i used 11 3/4 but take note, I had to get the dyna shock holes bored out to fit the stock shock bolt. It appears that VN750 shock bolt is slightly larger than a dyna shock bolt. Local machinist did this from me for $20.
luigit is offline
post #9 of 10 (permalink) Old 03-12-2010, 09:43 AM
On His Lady Vulcan
wkrizan's Avatar
True, they are smaller sleeves. What I did was punched out the stock sleeves and the dyna's and just hammered them back in using the OEM sleeves in the Dyna shocks. Worked for me and no money out of pocket...just a sore thumb from where I smacked it.
wkrizan is offline
post #10 of 10 (permalink) Old 03-12-2010, 11:39 AM Thread Starter
Thank you all. Great advice. I will definitively look into all these options. Take care.
Karl aka PR_V_Rider
