Slow ignition startup - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 28 (permalink) Old 03-10-2010, 12:46 PM Thread Starter
I just replaced all the spark plugs and wires. I had an arc to the engine from the front right plug wire and i do not see it anymore, after i just changed the plugs and wire caps. I must push the start button about 15 times until the engine finally runs continually. Does anyone have any idea what this would be caused by. the carbs were rebuilt last fall so they are up to snuff and i have run carb cleaner through the gas tank and installed a new fuel filter in both lines just to clean it out for the spring. I just want her to start up with less strain. Any suggestions are welcome.
Thanks,
Jim
antennaejim is offline
post #2 of 28 (permalink) Old 03-10-2010, 01:46 PM
The Professor
lance328's Avatar
Do you have a MF AGM battery or a standard wet cell? Did you use Iridium plugs or standard?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 28 (permalink) Old 03-10-2010, 05:04 PM
Calif Rider
weh44att's Avatar
I would say it sounds like a fuel problem. Check to see if your fuel lines maybe kinked, or the new fuel filters maybe the problem. You have it seems good spark.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #4 of 28 (permalink) Old 03-11-2010, 04:05 PM Thread Starter
standard plugs factory recommended and wet battery fully charged.
post #5 of 28 (permalink) Old 03-11-2010, 04:11 PM Thread Starter
i checked for kinks and don't see any. I did have the tank lined with that red stuff by a local radiator repair shop. they did the whole acid strip and all to get rid of the rust in the tank. the filter i speak of is the in tank filter attached to the fuel reserve valve. in addition brand new in great condition. i runs fine after the initial 15 start cranks.
post #6 of 28 (permalink) Old 03-11-2010, 05:25 PM
Do you mean the starter stops turning the engine over even if you are holding down the starter buttton? And after about 15 times of pushing the button the starter runs long enough for the motor to start running?
If so, check the button itself then clean the starters contacts.
If not, never mind.
post #7 of 28 (permalink) Old 03-11-2010, 06:22 PM
The Professor
lance328's Avatar
Are you using the choke when you start?
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 28 (permalink) Old 03-11-2010, 10:12 PM Thread Starter
it takes 15 times of cranking the starter for the engine to finally catch on. the starter sounds fine. I tried using the choke, and it just floods the engine and takes even longer than 15 times to start.
post #9 of 28 (permalink) Old 03-12-2010, 03:37 AM
The Professor
lance328's Avatar
Replace your CRAP lead acid battery with the battery in the link below and replace your plugs with NGK DPR7EIX-9 Iridiums. You will be amazed how well the bike starts.
Battery
http://cgi.ebay.com/ebaymotors/Deka-...item3eee173adb
Plugs
http://cgi.ebay.com/ebaymotors/NGK-I...item20afc1556c
You can get the plugs from Oriely Auto Parts for $7.00 ea.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #10 of 28 (permalink) Old 03-12-2010, 04:33 AM
revrenhex's Avatar
FWIW, the only way I can get mine to start is to start starting it with no choke, after about 1 revolution give it a quick flick on the throttle, and then move the choke on. This way it fires up within 3-4 revolutions, otherwise it wont start at all. just floods out and backfires if i start with the choke.
revrenhex is offline
