question:tranny cover/oilsight glass - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 03-03-2010, 07:53 PM Thread Starter
Concert connoisseur
wib714's Avatar
last year when I replaced my stator I forgot to run the wires through the clamp on the sight glass cover. so I figured no biggie I'll just take that one bolt out run the wire and replace the bolt. well that one bolt gave me a slight oil leak there.
I just got my gasket in the mail today from cheapcycleparts and was wondering if anyone has replaced theirs. looks like it should come off of there without having to lift the motor up or down, does anyone know for sure if it will come off and bypass the frame okay or are there any internal parts that will not make this that easy. thanks in advance!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 11 (permalink) Old 03-03-2010, 09:14 PM Thread Starter
Concert connoisseur
wib714's Avatar
hoping to fix it this weekend, supposed to get in the high 40's here, but I still gotta get tags and a new tire the following week and with fingers crossed the bad weather will be over for the year!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #3 of 11 (permalink) Old 03-04-2010, 10:38 PM Thread Starter
Concert connoisseur
wib714's Avatar
dang, 70 views and no one knows, where are you lance?
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #4 of 11 (permalink) Old 03-04-2010, 10:52 PM
The Professor
lance328's Avatar
I'm here, haven't been on much since my graphics card crapped out on my main computer.You have my number, call me!! Still up.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #5 of 11 (permalink) Old 03-04-2010, 10:55 PM
The Professor
lance328's Avatar
OOOOOOOPS!!! Wrong person. PM me your contact # I will call NOW!
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 11 (permalink) Old 03-05-2010, 12:52 AM
I would just torque the bolt to specs, and give it a little time, and see if the leak stops. Also check the torque of all the bolts in the area of the leak. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #7 of 11 (permalink) Old 03-05-2010, 08:57 AM Thread Starter
Concert connoisseur
wib714's Avatar
I torqued them down last year, slowed it but didnt stop it
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #8 of 11 (permalink) Old 03-05-2010, 11:21 PM Thread Starter
Concert connoisseur
wib714's Avatar
guess I'll take it off tomorrow and let you all know. hope it clears the frame!
new front tire will be here wednesday and hopefully by next weekend I'll be on the road, cold or not.
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #9 of 11 (permalink) Old 03-06-2010, 04:12 PM
How bad is the oil leak? is it just slight seepage, or an actual drip? I had a slight oil leak from what I thought was the oil drain plug for 3,000 miles, it was not enough to affect the oil level, I just stuck a piece of paper shop towel under it to absorb the oil. When I changed the oil, I replaced the o-ring, and it still leaked. That's when I discovered it was not from the oil drain at all, but from where the stator wires come through the case cover. It was running down the engine, and dripping off the oil drain plug. I have not addressed this yet, I just stuck a piece of paper towel under the stator wires to absorb the oil, and will leave it that way for now. I am certainly not going to pull the engine to remove that cover to replace the grommet, or whatever is in there, for such a tiny leak. I have owned a lot of old cars with an oil leak at the front main seal. I just let them leak. Replacing the front main seal requires removing and disassembling the engine, and unless it is a major leak, it just isn't worth it. If for some reason you try to remove that cover, and can't get it off, then you will have no choice but to pull the engine, as you will likely have made the leak a lot worse by loosening the other bolts. Jerry.
1979 Vespa P200E
post #10 of 11 (permalink) Old 03-06-2010, 04:47 PM Thread Starter
Concert connoisseur
wib714's Avatar
thats what im starting to think as well. fired it up today, been sitting since november. turned it to prime, choked it and it fired right up, died a couple times but two or three tries she stayed going and did not smoke at all which I thought it would. new tire coming wednesday.
as far as the leak it is not bad enough that I have to keep putting oil in it but just enough to make the bottom half of the engine and around it a little messy which drives me nuts, I like a clean machine and if I wanted an oil leaker I'd bought a harley. gonna go ahead and do the oil change though and ride and just keep my eye on it for now to see if it gets any worse if it does I'll address it then
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
