A Very Good Oil Read - IMHO - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 36 (permalink) Old 02-27-2010, 08:50 AM Thread Starter
I believe this man talks streight and knoweth his Oils, Dino & Syn., no sales pitch ...
http://www.vv.corvair.org/pipermail/...ly/028037.html
I stold it from another bike forum, sure explains plainly things I didn't know about oil...lol...
Kinda long but well worth the read...
post #2 of 36 (permalink) Old 02-27-2010, 07:18 PM
IronMan750's Avatar
You're right Dog! Totally worth the long read....That man is the oil king! Learned me a few things about oil today. I especially learned that I have been fooled by the oil change intervals of Mobile 1. I'd better change my ways....and my oil! Thanks for sharing that.
2003
*Battery connected at both ends!
*Real air in the tires
*New Registration sticker
*Seat wiped off
*Low AND Hi beam headlight!
*New #1157 tail light bulb
*Brake pedal still on the right
*Custom valve stem caps made from black plastic!
*Custom built ignition key from Kawasaki
Does anybody really care?
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car"
IronMan750 is offline
post #3 of 36 (permalink) Old 02-27-2010, 07:24 PM
Lebanon, NJ
Hiker's Avatar
That's why I still buy just decent dino oil at WalMart and change frequently. I'm not one to buy into hype or rhetoric easily...
Hiker is offline
post #4 of 36 (permalink) Old 02-28-2010, 02:43 AM
KIMMERLING's Avatar
wow. lots of info. Im running rotella 15/40
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
KIMMERLING is offline
post #5 of 36 (permalink) Old 02-28-2010, 11:25 AM
dirtrack650's Avatar
Very interesting read. Now I know why my bro's Triumph 900 triple requires Mobil 1 : heat. That engine is a cooker.
I will comment on using Lucas M/C synth in my vn: I rarely if ever have a problem with clutch drag and grind that's so common on our bikes. The gear box and shifting is much smoother with synth oil too.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #6 of 36 (permalink) Old 02-28-2010, 12:58 PM
VN750_DawgsFan's Avatar
So basically what I got out of that is synthetic oil doesn't extend your drain intervals and you should still change your oil according to your manufacturers recommendation. Right? Which is what I do anyway.
My daily ride
Metzler ME880s
NGK caps, wires and Iridiums
Coasters (made by Lance328), earshave and rejet with screws turned out 3 turns
Volt gauge w/ custom mounting cup by Lance328 wired into headlight bucket 13.5v-14v
National Cycles Plexistar 2 windshield
DEKA battery
Mutazu GA Black hard bags w/ custom support brackets and relocation brackets made by Lance328
Custom lowers made by Lance328
Vance&Hines Cruzer exhaust pipes
H.I.D. Conversion kit
VN750_DawgsFan is offline
post #7 of 36 (permalink) Old 02-28-2010, 02:07 PM Thread Starter
Yeah thats about what I got out of it also... I use Synthetic but now see that the benefit I get is not near as much as I had once thought...
Since my engine is air cooled I probably benefit mostly from the 25-30* better cooking point (in case of a traffic bog in extreme heat) and a bit from the more stable viscosity, and possibly a bit cooler running but not proven I don't think...
My recommended change intervals are 5K, I woouldn't want to exceed that anyway...
post #8 of 36 (permalink) Old 02-28-2010, 02:41 PM
Some truckers use Mobile 1 5w40 synthetic in thier trucks. They run it for about 60K miles. At 20K they replace the oil filter and add oil to bring the level to full, and again at 40K. At 60K they change oil and filter.
post #9 of 36 (permalink) Old 02-28-2010, 03:06 PM Thread Starter
He talked about that and the fact that they ran dual filters or something like a pre filter, then one with a very small micron rating to really clean up the oil...
I worked for a Gvt. agency that in the 60s and maybe early 70s replaced the stock filters on their cars and trucks with large canister type filters and didn't change oil, just the filters and added to top off, but they sold the vehicles at somewhere around 90K...
I just thought that was one of the best explained oil things I had ever seen and wanted to pass it on...
post #10 of 36 (permalink) Old 02-28-2010, 05:17 PM
The cat engine still has one filter in most cases, but it is rated as an (SS) for severe service for longer use and finer filtration. Some do use a spinner filter or an added on by-pass filter.
The thing that I do not like about this is that the oil is always very black, even right after the oil change.
