new ride review - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 02-24-2010, 10:33 AM Thread Starter
Rook's Avatar
new ride review
ok I went and picked up a 2003 last night so I am back on the road, however all is not well yet so lets review:
It has been stored since Oct and looses the rear cyl at times and cuts out terribly unless it is run at full choke. Thas new plugs but not iridiums
25,000 miles and the p.o. had no idea about the splines. Charging system looks good<sigh of relief> battery is new but not a MF, aftermarket pipes
So, correct me if I am wrong: iridium plugs, MASSIVE dose of Seafoam, Honda Moly60(?)on the splines, drill the plugs & reset at 2.5 turns out to start.
am I forgetting anything? (BTW there are some pics in my cross your fingers thread)
edit: I'm also going to replace the ageing acct's with a freshly rebuilt pair residing in my toolbox
Rook
Conway, AR
VROC # 30581
WBRA #90237-1
2009 1700 Nomad (mine)
2003 VN750 "Prozac" (now hers)
25'000 miles at purchase
Ears shaved
Cobra exhaust
So, why is a raven like a writing desk?
Rook is offline
post #2 of 7 (permalink) Old 02-24-2010, 10:37 AM
93VN750's Avatar
Congrats!
First thing to check is the carb vent line. Make sure it is not bottomed out in the right ear. Remove, cut off at 45 degree angle so when pushed back in it will still breath.
Also, sounds stupid, but check your gas. On reserve?
Go from there.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 7 (permalink) Old 02-24-2010, 11:47 AM
don't waste your time go get a set of TOC MCCT's... put the fresh ones one craigs list and eBay.
as for the cutting out on one cylinder, fuel could be a cause, or it could be electrical, check the coil pick up assembly wires where they leave the stator housing... mine were pinched right there and grounding out sporadically.
post #4 of 7 (permalink) Old 02-24-2010, 12:27 PM
Congratulations on the new ride Rook. I am sure you will get all the bugs worked out with patience, systematic diagnosis and a little help from the more skilled wrenches among us.
post #5 of 7 (permalink) Old 02-24-2010, 01:09 PM
Originally Posted by 93VN750 View Post
Congrats!
First thing to check is the carb vent line. Make sure it is not bottomed out in the right ear. Remove, cut off at 45 degree angle so when pushed back in it will still breath. Also, sounds stupid, but check your gas. On reserve?
Go from there. Jon
Yep, do the costless first, and the above could very well be the problem... Fresh gas...???
post #6 of 7 (permalink) Old 02-24-2010, 02:34 PM
Rub some dirt on it!
LibertyPilot is offline
post #7 of 7 (permalink) Old 02-24-2010, 04:04 PM
If it has been sitting since October, I would definitely remove, disassemble and completely clean the carbs. Yes I know it is a pain, but it is the only way you will ever get them completely clean. Running Seafoam through it, or soaking the float bowls in Seafoam may help, but you're better off starting with clean carbs, and then not letting that happen again.
AS for the cam chain tensioners, I would definitely go with the manual ones. I messed around with 2 different sets of stock ones before going to manual, and all I did was throw my money away, and cause myself a lot of frustration. Now I know better.
I hope the splines are ok, if there is serious damage, they might last a little longer, but with things like that, the more wear they have, the faster they wear. If Kawasaki was not going to lube the splines during assembly, they should have included it as part of the break in maintenance. If you follow the schedule in the manual, you will have damaged splines before the first scheduled maintenance is due on them.
I don't know about the iridium plugs, I have never used them, but may get some when I change mine again, in about 10,000-12,000 miles. So many here say they are better, I guess they must be.
Get an AGM maintenance free battery.
I have my pilot screws out 3 full turns, which is where it idles best, and it doesn't foul the plugs, but I have to turn them back in to 1 1/2 turns to pass the stupid emissions test.
Since the previous owner didn't seem to know or care about maintenance, I would just go ahead and service everything, the bike will be more reliable and last longer. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
