Speedo Inaccuracy - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 02-21-2010, 08:52 PM Thread Starter
Expert Advice Giver
mgough983's Avatar
Speedo Inaccuracy
Its like stuffing a tube sock in your speedo. I rode today for the first time with my GPS attached. My speedo is off @ 5%, as previously reported here. While I thought I was going 50 mph (acccording to the speedo), I was only going 56 or 57. I ran 80 mph for 1 minute, and sure enough, the GPS said 76; at 90 the GPS registered 85. I used to be satisfied at running up to 100 every now and then; I guess I'll have to run up to 105 now. I guess the inaccuracy can be a function of the front tire size, but I only have time to ride, not worry about that crap.
Now I have to explain to the wife, the tube sock in the speedo reasoning.
1994 VN750
32K+
Vance & Hines Cruzers
Avon Venom Front & Rear Tire
Mustang Seat
Fire and Steel Luggage Rack
Fire and Steel Engine Guard
Fire and Steel Sissy Bar
KawaVulcan Saddlebags
eBay Genuine Imitation Chrome Mirrors
Kury Chrome Levers
Battery Tendered
Taillight LED'd
Splines Lubed
Wheelies Popped
2009 Triumph Rocket III
1974 Suzuki TS250
mgough983 is offline
post #2 of 5 (permalink) Old 02-21-2010, 09:05 PM
Don't understand the sock thing, but yes the Vulcan 750 is highly optimistic. I don't have an issue with it now that I know about it. The fact is, I have never seen ANY vehicle that didn't have an optimistic speedometer. I have had cars and trucks that I put oversized rear tires on (speedometer was driven off the transmission) which corrected the speedometer error. I just make it a point to ride 5 mph faster than the speed limit, or in some cases, on interstate highways, as much as 15 mph above the posted speed limit. That's what it takes to keep up with left lane traffic around here. I have had my Vulcan up to 110 mph by GPS, it won't seem to go any faster, though I've heard of people getting 120+ out of them. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #3 of 5 (permalink) Old 02-22-2010, 07:07 AM
I have had the same issue in the past. The matter partially corrected itself when I put new tires on the bike. Still didn't make the speedo dead-on-balls accurate, but it dropped the difference by several miles per hour. You wouldn't think that the tire wear alone could cause such a difference in the 'size' of the tire, but the new tires cut the difference by a bit more than half.
Jeff
2005 VN750 Silver/Black
Kurykyn ISO grips
Mutazu LN Hard bags with wired LED Brake Lights
Kawasaki Rear Luggage Rack
Memphis Shades 21' Gradient Black Windshield
JWenhart is offline
post #4 of 5 (permalink) Old 02-22-2010, 10:34 AM
Love My Baby
rubyrick's Avatar
After I installed Pirelli tires with the upsized 110 up front I noticed my RPMs went up when the speedo indicated 60 mph, meaning my speedo was probably indicating higher than actual speeds before the tire change, and was more accurate now. According to my knowledge of where my baby's RPMs are at particular speeds, the difference was just under 5 MPH. Don't have a GPS to verify, but I always pay close attention to my speed & RPMs, along with the general feel of the bike at all speeds, just to know if anything needs adjustment.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #5 of 5 (permalink) Old 02-22-2010, 05:55 PM
I am a big guy at ~#300 and have a full size windshield on my 750, and have had it up to 150 km/hr on the speedo, which I now know was probably more like 140km/hr, (87 mph). I had more throttle, but ran out of nerve.
I just did some calculations last week, which I posted on a thread here, which indicate that the gearing on the Canandian and American bikes will yield ~14.5 mph in 5th gear, per 1,000 rpm.
So at 7K rpm, your speed is ~101.5 mph.
7,600 rpm yields ~ 110 mph. I think speeds higher than this with a large windshield or a rider much bigger than a jockey, are not going to be easy to acheive. You are past the torque and horse power curve peaks, and that last 900 rpm is going to be hard won.
Our redline is 8,500 rpm, which would theoretically yield 123.25 mph.
