Melted plastic on exhaust pipes and headers - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 01-13-2010, 12:11 AM Thread Starter
Hi to you all,
I have a question regarding how to remove melted plastic from my exhaust without scratching and making a mess out of the chrome...being a dumb ass and after a hectic day I travelled to work for the night shift, was tired and as soon as I switched off my bike I covered it with a plastic cover and you can imagine what happened..... ouch I only found out the next morning......
Any ideas anyone?
Cheers, Alan
malteser66 is offline
post #2 of 14 (permalink) Old 01-13-2010, 12:18 AM
Concert connoisseur
wib714's Avatar
I would try to pick at it with a fingernail or plastic scraper, I've used a brillo pad on mine to remove light rust without scratching it!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 14 (permalink) Old 01-13-2010, 01:46 AM
Here is a link to the Vulcan verses for a few suggestions: https://www.vn750.com/forum/showthread.php?t=1087
And another thread:https://www.vn750.com/forum/showthread.php?t=12327
post #4 of 14 (permalink) Old 01-13-2010, 04:11 AM
fartin'martin's Avatar
I've removed burnt on crud many times in the past by using a razor blade as a scraper when the exhaust is completely cold and then follow that up with one of those green pan scourers and Solvol Autosol. Then polish up.
A word of warning though. Don't nick your wifes/partners/mums last pan scourer and don't get too much blood mixed in with the Slovol!!!
Ride free, stay safe
Regards to all,
Martin
'88 FJ1200 3CV
1986 VN750 A2 (now sold to another old fart!)
Jardine fishtail pipes (de-goated)
Stator No 2
Avon Venom AM41/42 tyres
Sundance grips
etc
etc
fartin'martin is offline
post #5 of 14 (permalink) Old 01-13-2010, 04:24 AM
I have had good luck removing melted plastic from exhausts with aircraft remover. You have to brush it on very carefully, and make sure you keep it away from any painted surfaces. Solvents like lacquer thinner, acetone, or mek may get it off if it is not too bad, the problem with those is they evaporate so quickly, they don't have time to soften the plastic if it is very thick. I would keep anything metal away from chrome, and I wouldn't use Brillo pads or Scotchbrite pads either. They will cause dull spots on the chrome that no amount of polishing will remove. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 14 (permalink) Old 01-13-2010, 12:35 PM
93VN750's Avatar
Heat gun and a wooden scraper.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #7 of 14 (permalink) Old 01-13-2010, 01:22 PM
artemis_f0wl's Avatar
Send a message via AIM to artemis_f0wl Send a message via Yahoo to artemis_f0wl Send a message via Skype™ to artemis_f0wl
000 grade steel wool works really well too.
NIL ILLEGITIMUS CARBORUNDUM
Phil aka Art
"Vanessa"
1995 VN 750 (bought as 2nd owner 11/2008)
26,440 miles
Stator replaced (55 Days!)
V&H Cruisers
Relocate rear turn signals
Highwayman Saddlemen bags
Wingerline Highway bars
Ear Shave
Rejet carbs
R/R relocate
Kuryakin ISO Duallys all around
HD Heritage seat
12" ape hangers
To Do:
Some sort of new grips
Mirrors
Paint Job- should I do it myself?
artemis_f0wl is offline
post #8 of 14 (permalink) Old 01-13-2010, 01:31 PM
Undercover Sportbiker
AJCruzin's Avatar
When I melted part of my mechanics gloves to the front head pipe, I used a razor blade once it cooled to remove the majority of it. Anything left came right off with some Mother's metal polish. The key to any of the suggestions here is to be patient, otherwise you'll bollux up the pipe and leave tons of scars on it.
AJCruzin is offline
post #9 of 14 (permalink) Old 01-13-2010, 03:43 PM
richarsc's Avatar
Send a message via MSN to richarsc
Start the engine, end let the pipes get varm, then the plastic will melt, and it's just to wipe it of with some paper or piece of cloth.... Good luck..
Regards
Richard Schumann
VN750 -86
richarsc is offline
post #10 of 14 (permalink) Old 01-14-2010, 01:06 AM
First thing I thought of, and tried. Strangely enough it didn't work, though I don't know why. A heat gun might work, but it will have to be a real high powered heat gun, not a hair dryer. I still say don't use any kind of metal. Chrome scratches real easy. I have dull spots on my header pipes, where I used Turtle Wax chrome polish to remove the remains of baked on bugs. Jerry.
1979 Vespa P200E
