Help needed with repair - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 12-24-2009, 06:19 PM Thread Starter
I am at wits end with my sons bike. 2003 Vn750
I had it up on the lift when my buddy came over and we talked about a small miss at idle.
Unfortunately I decided to try and correct it with my limited knowledge of mechanics. I am getting better though (except for this time).
The bike does have after market pipes with no goats belly. Not sure what type they are.
I decided to eliminate the anti pollution nightmare and removed the lines and capped the ports as described.
The 5/8" line that runs from the breather under the tank was plugged as well. The 1/4" line that runs down the bottom was as well.
I drilled out the caps for the "air" mix.
The bike seemed to run well. Took it for a ride and liked it.
I added some K&N filters and since then I seem to have a lot of backfiring. I have removed the filters and I still get the backfiring.It is only on the left side that has the shorter pipe.
I'm going nut trying to figure this out. He is home for a couple of weeks and wants to ride. Right now i feel like I have blown it and and after a day of messing with it....I got nowhere?
Can it be the filters? K&N says no re-jetting required....sales pitch?
Stock cleaners are toast so re-install is not possible...foam was shot. Bike ran okay before though.
Help!
Which is what I will be doing....chugging that is.
crockettrider is offline
post #2 of 24 (permalink) Old 12-24-2009, 06:44 PM
Send a message via Yahoo to luigit
i was told with K and N and aftermarket pipes, the air mix should be as follows
2 3/4 turns out after you totally tighten them.
luigit is offline
post #3 of 24 (permalink) Old 12-24-2009, 07:10 PM Thread Starter
Thanks,
I have tried that and everything in between. Just can't figure out why it is the left side only. I did read about the filter oil being applied too heavily. I seem to have it running out of the filters and will clean them and re-apply.
Did the carbs suck it in? Heck i don't know anymore
post #4 of 24 (permalink) Old 12-24-2009, 07:30 PM
sounds like too much oil... and too lean on the rear carb... turn the screw in all teh way then back out 2 1/2 turns... should be very close to gone at this point... keep backing out the screw untill miss is completely gone
post #5 of 24 (permalink) Old 12-24-2009, 07:37 PM Thread Starter
Thanks for the reply,
I have tried that. I can't understand why my screw go so deep I can barely get a small driver on it and seems to go out as far a 5 turns + without falling out? I took the lead cap off, that is the only screw for each carb with a lead cover I assume?
I saw about oil in the air box? Is there enough vacuum to suck it up there....the filter oil that is.
Thanks again
post #6 of 24 (permalink) Old 12-25-2009, 08:13 AM
yes there is enough vacuum to suck the oil that deep...i would clean the filters and reapply a LIGHT coat of oil onto the filters, adjust the carbs to 2 1/2 turns out then start from there on the carb adjustments.
post #7 of 24 (permalink) Old 12-25-2009, 08:53 AM
Vintage bike addict
antiq's Avatar
Pull the rear plugs and see what color they are. If they are clean and white. Too lean. Black too rich. dark eggshell is about right.
Eleanor Roosevelt.
antiq is offline
post #8 of 24 (permalink) Old 12-25-2009, 09:28 AM
Vintage bike addict
antiq's Avatar
BTW an exhaust air leak can also cause the popping.Check your connections from the jug back.
Eleanor Roosevelt.
antiq is offline
post #9 of 24 (permalink) Old 12-25-2009, 10:33 AM Thread Starter
Thanks again guys/gals?
The plug is definitely running rich...wet when pulled. After a good nights sleep I thought about pulling the filters and applying a light coat of oil....as mentioned here.
It is very heavy on the filter as it was a nozzle type applicator (not spray).
I really do appreciate the help and will hope these recommendations work...now if the wife will let me sneak away and try????
post #10 of 24 (permalink) Old 12-25-2009, 06:16 PM Thread Starter
I have one question left before I set the bike on fire and throw it in the lake....
I have tried every combination of settings etc. I can think of.
When I disconnected the anti pollution hoses the main line that comes for the air chamber was plugged (by me). I am wondering if that is messing with the air flow as it seems to be air related.
It will run pretty well without air filters now but as soon as I put them in I get a lot of backfiring.
Should I have left that hose unplugged?
Thanks in advance.
