Bobber Build in progress - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 45 (permalink) Old 12-20-2009, 11:26 PM Thread Starter
jebusbud's Avatar
Send a message via Yahoo to jebusbud
Hey everyone, seen some pretty cool bikes on this forum, just wanted to post my winter project. I cut the tail of the frame off to clean up the solo look, gonna mount a flat fender, solo spring seat, redid wiring harness to remove turn signal circuit and relocate horn, highbeam and ign switch. gonna do the ear shave and get exhuast done this winter too. here is what i have so far, more pics to come
Name:	vn 750 bobber 001.jpg
ID:	2475   Click image for larger version
Name:	vn 750 bobber 002.jpg
ID:	2476   Click image for larger version
Name:	vn 750 bobber 003.jpg
ID:	2477   Click image for larger version
Name:	vn 750 bobber 004.jpg
ID:	2478   Click image for larger version
Name:	vn 750 bobber 007.jpg
jebusbud is offline
post #2 of 45 (permalink) Old 12-21-2009, 07:40 AM
Send a message via Yahoo to luigit
just an FYI
This is exactly what the previous owner attempted to do with my VN750 project. In my case, he only partially completed one side. Mine is now at the welders to get the tail pieces re attached. Had we have known each other, we could have switched frames HAHAH. Too funny. Good luck with your project looks good so far.
luigit is offline
post #3 of 45 (permalink) Old 12-21-2009, 08:08 AM
Interesting build ya got there! Looks good
One question for ya...
How do ya operate the suicide shifter with still having the clutch on the same side?
There was a pic someone had of another Vulcan with a suicide shifter, but it was routed to the right side.
Unfortuately though, it was on Yahoo photos, which is no longer around and the only other pic is too small to really see it.
post #4 of 45 (permalink) Old 12-21-2009, 08:30 AM
Scoop's Avatar
Good luck with the bobber build. Looking good so far.
Hyper - I think he'll have to go to a foot operated clutch OR relocate the hand operated clutch to the suicide shifter so that both can be operated with the same hand.
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #5 of 45 (permalink) Old 12-21-2009, 10:50 AM
A suicide shifter, or "jockey" shifter almost always has the clutch mounted to the shifter handle. I've seen a lot of them around here on Harleys. They look awkward and clunky to me, kind of like driving a truck. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 45 (permalink) Old 12-21-2009, 11:35 AM
Vintage bike addict
antiq's Avatar
The suicide shifter is so named for good reason. I don't get the attraction of this mod at all.
Eleanor Roosevelt.
antiq is offline
post #7 of 45 (permalink) Old 12-21-2009, 11:36 AM
Go work, looking forward to seeing it when you are done. Maybe I can ride over in spring.
Keep up the good work.
post #8 of 45 (permalink) Old 12-21-2009, 02:50 PM Thread Starter
jebusbud's Avatar
Thanks for the compliments guys. In regards to the hand shifter: tried the clutch on the shifter, looks cool and works great, but a HUGE pain in the ass trying to park the bike. Either hold the clutch and steer w one hand, or hurry and shift to neutral before you park. I imagine a foot clutch would incure the same type of problems. As far as the current setup, I just float the gears going up and reach over while shifting down. Still have a long way to go with this build, but i'll get it rideable again for the start of the season, then build a front end for next winter.
jebusbud is offline
post #9 of 45 (permalink) Old 12-21-2009, 03:14 PM
Originally Posted by antiq View Post
... I don't get the attraction of this mod at all.
Like most any other mod.... To be different
post #10 of 45 (permalink) Old 12-21-2009, 03:23 PM
'85 Bobber
drodeo17's Avatar
Bike is looking good. I was thinking about doing the same shifter style on mine. Keep up the good work!
Completed
Stripped down to motor and frame
Front- 100/90-19 Avon Wide White Walls (cause I couldn't find the 110's)
Rear- 170/80-15 Avon Wide White Walls
Custom Lowering bracket (no shocks)
Powder coated rims Red
14" Apes (cause they didn't have 16" in)
Custom Seat
Ear Shaved
Aftermarket headlight & tail light
Flat Black Paint
Custom Exhaust with Wrap
New Turn Signals
kuryakyn 6180 Grips with helmet locks
Highway Brackets from ccspinner
Kuryakyn Longhorn Offset Dually Highway Pegs
drodeo17 is offline
