Removing Reflector Tape - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 03-11-2006, 10:39 PM Thread Starter
The previous owner placed strips of reflector tape all over the bike -- which for safety, is cool... but it looks a little goofy. I can't peel it off, as I hoped. And it's tough and slow-going getting it off the bike using my fingernail. I'm nervous about scraping the paint with any tool.
Any suggestions, O Sage Vulcanites?
Oddboggle
Oddboggle is offline
post #2 of 5 (permalink) Old 03-11-2006, 11:17 PM
reflective tape removal
Try peeling the tape and then using goo off which should be available in any Walmart. For scraping the tape off get a nylon scraper(push stick)used by glass shops if carefully used it should not harm the paint.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #3 of 5 (permalink) Old 03-12-2006, 05:51 AM
also if you can get someone to assist you, what you can do is get the tape started where you can lift a corner and the use mono fishing line between the bike and the decal. working the line back and forth against the body part while your assistant slowly gently lifts the tape off the bike. hope this helps.
safe riding free
free wheel-e is offline
post #4 of 5 (permalink) Old 03-12-2006, 05:48 PM
HAWK
Ccspinner's Avatar
You can also try using a heat gun on low or a hair drier, the heat should soften the adhesive. works on car's at the dealer I work at.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #5 of 5 (permalink) Old 03-13-2006, 12:03 AM Thread Starter
Talking
Thanks for the tips! Between a hot rag, a plastic pie serving knife, my fingernails, and some Goo off, I am now reflecting tape free... and prolly invisible.
Oddboggle
