Painting Chrome - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 12-08-2009, 12:34 PM Thread Starter
Painting Chrome
since my bike doesnt seem to be selling i was thinking of painting the chrome pieces black for a different look.
pipes i can wrap in muff tape, front forks i can probably find black boots for...
the rest... any suggestions for painting chrome?
skaere is offline
post #2 of 13 (permalink) Old 12-08-2009, 12:38 PM
My suggestion would be leave it chrome. If I were a buyer and heard there was chrome under all that black I'd be like, "Wait what?" I'd sooner lower the price than ruin my chrome. Just me though...
LibertyPilot is offline
post #3 of 13 (permalink) Old 12-08-2009, 12:47 PM Thread Starter
i understand, the only reason i would paint the chrome is if i were to keep her.
which im tempted. im not out to give away a bike.
skaere is offline
post #4 of 13 (permalink) Old 12-08-2009, 12:51 PM
dirtrack650's Avatar
I've never had luck painting chrome, unless you take the chrome off first - very difficult and time consuming.
Kawasaki Spectre came with black chrome bars - btw.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 13 (permalink) Old 12-08-2009, 01:00 PM Thread Starter
yeah, i think i can get similar bars to the bend i have in black.
honestly, im only looking at painting a couple items... and i think most are plastichrome.
headlamp assembly and gauges
side covers
rear pass brackets
lower forks
triple and perhaps upper tubes... perhaps not
wheels.... and i think people have had good success with these...
anyhow, its just a thought at this point. worst case i guess i could sandblast them first...
skaere is offline
post #6 of 13 (permalink) Old 12-08-2009, 01:02 PM
Undercover Sportbiker
AJCruzin's Avatar
When I had mine, I used 320 grit fine sand paper to rub off the finish then primed, then painted. It looked good, but nowhere near professional level. The fact that your bike isn't selling is due top the season, not the look. Right now is a buyer's market. Next March it will swing back the other way.
AJCruzin is offline
post #7 of 13 (permalink) Old 12-08-2009, 01:51 PM Thread Starter
i figure as much... im just torn between selling it and keeping it and finishing my originial "vision"....
i hate selling my stuff.
skaere is offline
post #8 of 13 (permalink) Old 12-08-2009, 02:46 PM
Originally Posted by ajcruzin View Post
when i had mine, i used 320 grit fine sand paper to rub off the finish then primed, then painted. It looked good, but nowhere near professional level. the fact that your bike isn't selling is due top the season, not the look. Right now is a buyer's market. Next march it will swing back the other way.
x2...
post #9 of 13 (permalink) Old 12-08-2009, 03:28 PM
The headlight bucket for a Spectre is black if you can find one.
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Emgo air filters
Tank bag-Eclipse
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Rotella T6
post #10 of 13 (permalink) Old 12-08-2009, 04:23 PM
Most of the pieces you mentioned are plastic or aluminum. The headlight bucket other than the retaining ring, is "chrome plastic" Which means you should just be able to rough them up with 200 grit sandpaper and be good to go. (I think 320 is a bit too fine )
The forks are aluminum, but do have a clear coat finish on them that needs to be sanded off before painting. The "chrome" gauges are also plastic, I sanded mine and painted them black. Rustoleum makes an "All Surface" spray paint that works well on plastic items. I was not impressed with the Krylon Fusion for plastic.
Much of the rear chrome used to be unplated aluminum, like the whole seat rail and passenger backrest and the rear foot peg bracket. You might want to see if there is a member with an older bike that will swap out his plain aluminum pieces for your chromed ones. This will make them easier to paint for you and make a member with a non chromed bike happy.
