squeal? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 12-01-2009, 01:16 AM Thread Starter
1995 750 vulcan
w.ben14's Avatar
squeal?
ive just recently resurrected a 95. ive noticed a high pitched squeal on the right side, it is intermediate, but worrisome. it only happens occasionally and a blip of the throttle can make it go away..........??????
w.ben14 is offline
post #2 of 8 (permalink) Old 12-01-2009, 11:22 AM
Could be something as simple as a loose heat shield on the exhaust, or other loose bolt somewhere.
That's the first thing I'd check.
Not a bad idea to check all the bolt/nuts as well as electrical connections every once in awhile anyhow.
post #3 of 8 (permalink) Old 12-01-2009, 12:54 PM
Resurrected a 95 huh? Did you check your air cleaner for mice?
LibertyPilot is online now
post #4 of 8 (permalink) Old 12-01-2009, 01:29 PM
check for vacuum leaks too
post #5 of 8 (permalink) Old 12-01-2009, 04:10 PM Thread Starter
1995 750 vulcan
w.ben14's Avatar
hmmm.....no fur on the plugs.....i dont think its mice
sounds like its from the clutch cover......or around there....is the water pump on that side..?
w.ben14 is offline
post #6 of 8 (permalink) Old 12-01-2009, 06:20 PM
If there is a chrome tube about a half inch in diameter that makes a 90 degree bend there is a water pump on that side
post #7 of 8 (permalink) Old 12-24-2009, 08:11 PM
Curious if you found any solutions. My 95 makes the same noise coming from the clutch cover at 3000 rpm or so. Thanks
BriSan90 is offline
post #8 of 8 (permalink) Old 12-24-2009, 08:30 PM
IMBoring25's Avatar
My experience with the water pump bearing had the noise mostly occurring at idle (Or maybe I could just mostly hear it at idle).
IMBoring25 is offline
