Phillips screws not the same as JIS (Japanese Industrial Standard) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 10-16-2009, 03:27 PM Thread Starter
Exclamation Phillips screws not the same as JIS (Japanese Industrial Standard)
Bordolover`s thread on the correct screwdrivers for metric cruisers prompted me to make a search on what JIS was, and how it differs from Phillips screws. I found the following link. http://www.instructables.com/id/SAD3S3IFOVXPGXR/ (This is the same link that I put on that thread.)
post #2 of 11 (permalink) Old 10-16-2009, 05:31 PM
STUMPYSKAW's Avatar
Thanks for the info. I cleaned at least 5 carbs in the past couble of weeks, and have to be very carefull whith the bowl screws. I've had to use my impact driver on a couple of them( just tap it hard enough to break em loose). I'm in the market for a set of JIS drivers now. Thanks Hoss.
"DAISY" 85 VN 700 19K
Owned since 09/12/09
Done list
Metal radiator drain plug
Removed exhaust baffles
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
VN900 seat on my VN700
https://www.vn750.com/forum/showthread.php?t=12903
Debaffling my stock pipes
https://www.vn750.com/forum/showthread.php?t=12756
STUMPYSKAW is offline
post #3 of 11 (permalink) Old 10-16-2009, 05:57 PM
The Professor
lance328's Avatar
I use the Hozan D-155-100 JIS +2 for the carbs.
http://www.ikaswebshop.com/jisphilips.html
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 11 (permalink) Old 10-16-2009, 06:43 PM
Undercover Sportbiker
AJCruzin's Avatar
A number 2 phillips CAN work, but you have to be careful. COnstant downward pressure to keep it seated. Of course, the OEM tool kit has hte right one if you're lucky enough to have that.
AJCruzin is offline
post #5 of 11 (permalink) Old 10-16-2009, 07:09 PM Thread Starter
I have thought for the past year and a half that the screwdriver bit in the Kawi tool kit was a #3 Phillips. I know it is bigger than a #2. I need to go dig it out and compare the flatness of the tip with a known #3 Phillips. I have made do with Phillips drivers for the little bit of work on the bike so far, but will file the tip of one #2 screwdriver a little bit flat, to see if that improves grip.
post #6 of 11 (permalink) Old 10-16-2009, 08:00 PM
Not sure why there are two posts on this same subject?
But I always thought the hot ticket was to replace all the phillips head (or JIS head) screws on your bike with Allen heads... Never had one of those strip out on me yet........
post #7 of 11 (permalink) Old 10-17-2009, 02:25 AM
Jace Bror's Avatar
Yeah allens are much better. Plus for removing them you can get better leverage.
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #8 of 11 (permalink) Old 10-17-2009, 02:29 AM
Jace Bror's Avatar
Did anybody else see the side bar add on the first page linked on here. The one for the "Trick to white teeth". That pic threw me for a sec
Sold 750 (9-09)
Mustand Seat (6-09)
Kuri grips (8-08)
post #9 of 11 (permalink) Old 10-17-2009, 08:04 AM
GIMPYRDR's Avatar
Thanks for the info OlHossCanada. KM I have had allen head bolts and screws strip the heads before, admittedly not on my bike.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #10 of 11 (permalink) Old 10-17-2009, 10:07 AM
STUMPYSKAW's Avatar
just ordered a set #8971
https://www.rjrcooltools.com/shop_it...?subcat_ID=138
Done list
TOCMAN. ACCT's
VN900 Seat
TO Do list
To much to list
