It wasn't the stator - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 10-02-2009, 10:51 AM Thread Starter
Straight roads are evil
Thought my stator was going bad. Symptoms:
My voltmeter is plugged into the headlight, so it normally reads 12 volts. On one ride, it went to 10. Ran a wire directly from the battery, got new readings. Cold, the bike was putting out 14.1, no problem. But, when fully warmed up, it dropped to 12 and stayed there, sometimes going lower, like when idling at a light.
Getting home, the battery tender normally goes green (fully charged) within 30 seconds. Instead, it was taking many hours.
Starting the bike, especially on cold mornings, wasn't instant like normal, the starter took a few more revs than usual.
Adding all that up, I thought the stator had gone bad again. ^&%$#@. Had the battery tested, it was OK, so took the bike to the shop.
They called later and said the stator was fine, it was the three yellow wires out of the stator that had the problem. They have bullet connectors, and one connector had failed, so all the current was going through the other two wires. They replaced the connectors, and all is well again.
Whew! Check those yellow wires, if they look burnt there may be a problem.
Now it's time to RIDE!
p.s. just rolled over 45k
2006 VN750 (SOLD)
63160 miles
Mustang seat
Red spark plug wires
Stainless Steel brake lines
Stiffer fork springs
Givi bags, Wingrack mount
GPS Mount
Pashnit sticker!
EQPlayer is offline
post #2 of 8 (permalink) Old 10-02-2009, 11:02 AM
fergy's Avatar
That's great! Glad you're back on the road!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 8 (permalink) Old 10-02-2009, 11:07 AM
dirtrack650's Avatar
Mine are CRISPY, have been for 8 years. I cleaned and greased the unions w/ no problems. I think I'll take a day this winter and replace the wires w/high temp automotive wire.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 8 (permalink) Old 10-02-2009, 12:49 PM
Is it hard to check these wires?
Thanks
accord_guy is offline
post #5 of 8 (permalink) Old 10-02-2009, 01:16 PM
i removed my connectors and had them soldered together. Usually a crispy wire means the regulator has gone bad. so check those regulators!
6204 is offline
post #6 of 8 (permalink) Old 10-02-2009, 03:48 PM
Drive less, ride more...
theauhawk's Avatar
Thanks EQ...for the info and the update....
Glad to learn your issue was in fact a bad connector--and not the stator.
'05 VN750
theauhawk is offline
post #7 of 8 (permalink) Old 10-02-2009, 04:48 PM Thread Starter
Thanks
Super easy. Remove the left side cover and there they are.
2006 VN750 (SOLD)
63160 miles
Mustang seat
GPS Mount
Pashnit sticker!
EQPlayer is offline
post #8 of 8 (permalink) Old 11-01-2009, 12:24 PM
they are behind the covers... ohh wiat my covers are off..
