speedo cable - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 09-28-2009, 07:57 PM Thread Starter
Concert connoisseur
wib714's Avatar
speedo cable
last week my speedo stopped working for about a 1/2 mile then it started working again. today it quit again and did not start working this time. do you think it might be toast or could it maybe just be lubed up or something? it does have 35,000 miles on it.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 4 (permalink) Old 09-30-2009, 10:07 PM
IronMan750's Avatar
It could be your cable or more likely your meter gear assembly on your front wheel. Mine went out right at 20k. My speedometer started bouncing around and then became weaker until it just quit. Turns out that the meter gears were worn out but the cable was still good. Lubed up the cable and found a used meter gear with 7k on it for $25 bucks (incl shipping) on feeBay and replaced it (front wheel has to come off, good time to check those bearings though!). If the meter gear turns out to be the problem, trust me, don't try to rebuild it or anything...just replace it.
Hopefully it's just your cable...definately a cheaper and easier fix!
2003
*Battery connected at both ends!
*Real air in the tires
*New Registration sticker
*Seat wiped off
*Low AND Hi beam headlight!
*New #1157 tail light bulb
*Brake pedal still on the right
*Custom valve stem caps made from black plastic!
*Custom built ignition key from Kawasaki
Does anybody really care?
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car"
IronMan750 is offline
post #3 of 4 (permalink) Old 09-30-2009, 10:52 PM Thread Starter
Concert connoisseur
wib714's Avatar
its working again now!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #4 of 4 (permalink) Old 10-01-2009, 09:49 PM
IronMan750's Avatar
Might still be worth check'n out though. If it goes out in the middle of a long ride, like mine did, it sucks to travel without a speedo.
By the way....Love your bike's name! Best one I've seen!
2003
*Seat wiped off
