Do the rear turning signals turn on when bike is running? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 09-17-2009, 09:39 PM Thread Starter
Chavisimo's Avatar
I was just wondering. When the bike is running, only the font turning signals are on (not flashing) and rear are not. Is this normal?
Thanks,
Chavisimo
Chavisimo is offline
post #2 of 12 (permalink) Old 09-17-2009, 09:46 PM
Hoser
junkyardroad's Avatar
They are not. If you look under the seat at the connectors, they have only 2 wires, ground and power-turn flasher. The fronts have three, ground, power-ignition on, turn. It would be nice if they did turn on, like a running light.
1986 VN750A(2) 12224 miles.
junkyardroad is offline
post #3 of 12 (permalink) Old 09-17-2009, 09:46 PM Thread Starter
Chavisimo's Avatar
Looking through the forums IMBoring25 answered the question. Front turning signals have 2 filaments. 1 is for constantly on and other is for flashing. Rear just has 1 and its for flashing. Guess I should have done my research better. Didn't see the post my first search.
post #4 of 12 (permalink) Old 09-17-2009, 09:47 PM Thread Starter
Chavisimo's Avatar
Junkyardroad,
I agree. It would add some extra lighting that would make the bike more visible at night time.
post #5 of 12 (permalink) Old 09-17-2009, 09:50 PM
Originally Posted by junkyardroad View Post
They are not. If you look under the seat at the connectors, they have only 2 wires, ground and power-turn flasher. The fronts have three, ground power-ignition on, turn. It would be nice if they did turn on, like a running light.
If they did, atleast here in PA, they'd have to be red when on as a running light. Could be amber or red when used as a turnsignal, but amber always in the rear is a no-no and would get ya pulled over.
post #6 of 12 (permalink) Old 09-17-2009, 11:32 PM
IMBoring25's Avatar
http://www.electricalconnection.com/...g/roadbike.PDF
Some big promises made there. I don't know anyone with them.
IMBoring25 is offline
post #7 of 12 (permalink) Old 09-18-2009, 01:33 AM
I took the front light assembly and installed at the rear. I made a red lens from a trailer light and now I have three red running lights to the rear.
post #8 of 12 (permalink) Old 09-18-2009, 09:12 AM
VN750_DawgsFan's Avatar
Lance did his with some kind of kit he order. I'm gonna get him to do the same for mine once I get bags and relocate the rear signals. PM him to see what he did.
Hey Hyper, I think it's the same here in GA because Lance has red lens on his now also.
My daily ride
Metzler ME880s
NGK caps, wires and Iridiums
Coasters (made by Lance328), earshave and rejet with screws turned out 3 turns
Volt gauge w/ custom mounting cup by Lance328 wired into headlight bucket 13.5v-14v
National Cycles Plexistar 2 windshield
DEKA battery
Mutazu GA Black hard bags w/ custom support brackets and relocation brackets made by Lance328
Custom lowers made by Lance328
Vance&Hines Cruzer exhaust pipes
H.I.D. Conversion kit
VN750_DawgsFan is offline
post #9 of 12 (permalink) Old 09-18-2009, 12:30 PM
you can always modify the wiring in order to get running lights.
6204 is offline
post #10 of 12 (permalink) Old 09-18-2009, 06:40 PM
The Professor
lance328's Avatar
I used a tail light converter for trailers and removed the 1156 sockets and installed 1157. You do have to use red lenses. The converter allows brake/turn function from the same filament.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
